I appreciate your input.
You can see it here: http://s197.photobucket.com/albums/aa7/linggowa/ Thanks
Website |
#2 |
What are you trying to notch?
If you are trying to kill the 7KHz break up node of the woofer - this does nothing to help. In that case - you need a series notch filter (that is inductor / cap / resistor all wired in series, then paralled with the woofer). You then increase or decrease the resistor to reduce / increase the amount of cut. In zaphs design - he uses just a cap / inductor without a resistor to create the deepest notch possible precisely at the L18's largest breakup node. Your parallel notch doesn't achieve anything (I've modeled on Zaph's L18 measurement). Hope that helps, David. |
#3 |
Here's your network (alone) modeled on the L18 measurements provided by Zaph.
David. |
| Seas W18EX-001 and notch filter | Kelly McDonald | Multi-Way | 10 | 6th March 2012 08:11 AM |
| Seas L18RNXP | GOWA | Multi-Way | 0 | 14th September 2008 09:26 AM |
| L18rnxp + Lcy Ribbon? | GOWA | Multi-Way | 5 | 2nd May 2007 01:14 AM |
| Wanted: Seas W17EX001, Usher 8945P, Seas CA18, or somewhat similar mid-woofer. | Spasticteapot | Swap Meet | 2 | 7th March 2007 04:06 PM |
| Page generated in 0.06300 seconds (72.62% PHP - 27.38% MySQL) with 11 queries |
