Old 29th October 2007, 11:12 PM   #1
Default Question On Ports And Cones Cancellation and Relative Size
Speaker A, an 8 inch speaker of 32 sq in cone area, is in a Transmission Line Enclosure. At 300 Hz it's SPL @ 1M/1W is 90 dB.
The port, (terminus) of that Transmission Line has an area of 96 sq in-three times the cone area. It too has an SPL of 90 dB @1W/1M. Assume distance between port and terminus are negligible.
How can I find the summed output in SPL of cone and terminus at 300 Hz if:
A) Both cone and terminus are in phase?
B) The terminus is 90 deg out of phase with the cone?
C) The terminus is 180 degree out of phase with the cone?
I'm trying to find the relationship between cone size, port size and phase. If anyone knows an equation, that too would be greatly appreciated.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Question about using 2 ports of unequal length. Why? Brisso57 Multi-Way 19 22nd August 2008 09:09 PM
What do you use? Not technical but relative. hdlcx2 Tubes / Valves 11 4th August 2008 08:12 PM
Plastic cones or paper cones? beppe61 Multi-Way 19 19th February 2006 11:37 AM
NuBee Question: 2 ports = half the length Pete H Subwoofers 5 4th May 2005 02:02 AM
dumb question on ports and volume mitch808 Multi-Way 5 7th June 2004 10:48 PM
Page generated in 0.06526 seconds (67.47% PHP - 32.53% MySQL) with 10 queries
