Suppose I have a two cubic foot box, (56L). If I use a 2" diameter port 5 inches long, any of a number of programs can tell what the box will be tuned to.
But suppose instead of a piece of straight pipe, I use a conical port-one that is 2" diameter on the side which faces the outside of the box, but a 4" diameter on the interior side. No flare, just a conical expansion, 5 inches long, from 2" to 4". Does anyone know how to calculate which frequency the 56L box will now be tuned to? I can probably simulate one using Martin J King's software, but I prefer an equation, if possible.
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#2 |
I would also be interested in a simple formula to calculate this, because Solen does sell parabolic port tubes, which I think would be nice to use (however it is uncertain from Solen's specs on whether the diamater of the port is measured at the inside or the outside).
You could calculate the tuning frequency in a rather lengthy task of dividing the port into sections, for example 1/2". Take the diameter of every 1/2" section and calculate the port for that section. Combine the result of all the sections to get an approximated result. I think this should work, though I haven't done the calculations myself to prove it. |
#3 |
not sure of the need for this. Basically you are creating a small hjorn or a small transmission line, depending on whether the largest diameter is inside the volume or not.
However, to be effective, either would have to longer than 5"... you may be able to approximate the length (very roughly by looking at the length of a Helmholtz resonator with , say 5" Length, and a diametre of 3.5 inches. That will give you some idea. did a quick calculation: f(h) would 52 Hz.
stew ☮ -"A sane man in an insane world appears insane." |
#4 | |
I did that a couple of years back. You can see what I came up with here. By the way, I would *never* recommend tuning any kind of vented box using a piece of software. You *must* measure the impedance peak to tune the box properly. No matter how good your model is, it will ALWAYS be off by a few hz, due to boundary reinforcement, the location of the port mouth and exit, etc. Go get yourself a multimeter - the software model is only a starting point. |
#5 |
You can calculate the acoustic mass* of the port by using the integral
Ma=I rho0/S(x) dx where I is the integration sign, rho0=1.2 kg/m³, S(x) is the cross-sectional area of the vent as a function of the position along the tube. Integrate between the tube ends. The acoustic mass of the co-oscillating air has to be added. Thereafter, the Helmholtz angular frequency can be calculated as wh=1/sqrt(Ma*Ca) Ca=Vb/(rho0*c²) *Acoustic mass is NOT measured in kg, but kg/m^4 ...but I dunno if that was simple, though. |
#6 | |
Intuitively, making a conical port is somewhat like making a lossy acoustic diode. Flow in one direction is easier than in the other, meaning that the damping on the cone due to box resonance will be unequal over a full cycle, increasing distortion in the region where the port acts....
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#7 | |
As described a fairly pointless exercise, what is the purpose ? |
#8 | |
The use of a conical port IS fairly pointless, but if the wider end is on the INSIDE of the box, it would actually be *less* efficient than a traditional port. The only advantage I could envision would be to stagger the port resonances - and there are better ways to do THAT. |
#9 | |
Maybe this is the whole purpose of the device, maybe it is not a loudspeaker at all |
#10 | |
For most of the people on this forum, yours would certainly be exactly the right answer. For myself, however, that means I'm in deep trouble already.
| Bass Reflex port for Usher 701 kit | nippontiger | Multi-Way | 7 | 16th September 2008 03:11 PM |
| Bass reflex port question | Javachip | Multi-Way | 12 | 11th April 2006 12:11 PM |
| Tuning bass reflex port | beamnet | Multi-Way | 0 | 28th September 2005 01:03 PM |
| Port location in a bass reflex box | quasi | Multi-Way | 24 | 30th April 2005 03:53 AM |
| what the max Air velocity of bass reflex port? | Audist | Multi-Way | 4 | 7th February 2005 08:43 PM |
| Page generated in 0.13010 seconds (83.35% PHP - 16.65% MySQL) with 10 queries |
