Old 25th October 2007, 09:33 PM   #1
Onur is offline Onur  Belgium
Onur's Avatar
Send a message via ICQ to Onur Send a message via MSN to Onur
Default The relationship between air volume and SPL
Hello,
I have examined this web page;
http://www.angelfire.com/comics/illustartions/
There you can find a relation between the air volume and SPL. Can somebody please explain me how it is possible to calculate the needed air volume which needs to be moved in order to achieve certain SPL value?
Thanks in advance
Onur
Master is the master of his own Happiness
Old 26th October 2007, 12:35 AM   #2
fpara is offline fpara  Canada
You should add: "for open baffles"
Old 26th October 2007, 01:13 AM   #3
Send a message via MSN to noodle_snacks
It would depend on frequency too.
Old 26th October 2007, 07:36 AM   #4
Onur's Avatar
It is depended on the frequency and the volume of the space in which the sound is generated, am I right? Without knowing the volume of the space in which the pressure wave is generated, how could he came up with such results?
However, if there is a way to calculate the needed air volume which needs to be moved for open baffle speakers for a specific frequency, I would like to examine that. Can somebody forwar a link?
/Onur
Old 26th October 2007, 07:49 AM   #5
Check this out:
http://www.linkwitzlab.com/models.htm#A1
Scroll down, there is an explanation as to how the displacement is related with frequency and some theory.
Old 26th October 2007, 11:17 AM   #6
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Just my 2 cents, Calculations only valid on axis and no baffle considerations made and I could be wrong when not understanding fully what you want to compare? See the picture:
b
1(1)
Old 26th October 2007, 03:55 PM   #7
More odd shortcomings:
Look again at the table for 112 dB where 100 cu in equates 645.16 cu cm, that is 1 cu in= 6.45 cu cm and obvious wrong as 1 cu in = 2.54^3 and about 16.4 cm^3, then all the tables are systematically erroneous.
But worse is this assumption:
‘…For a totally open-baffle ELF design, the roll-off rate will be 18dB/octave (room gain not taken into account). For an aperiodic design such as the one I'm proposing, it will be much closer to 12dB/octave…’
...as the SPL losses, when loading aperiodic from 18 dB to 12 dB/octave is not included.
b
Old 27th October 2007, 01:30 PM   #8
sreten is online now sreten  United Kingdom
The maximum levels a sealed box driver can produce at low frequencies
assuming it has enough juice to get it to excursion limits is solely
determined by the Vd (volume displacement of the driver) Sd x exc.
Maximum levels obviously drop with frequency, the actual levels are
fairly arbitary, usually they are calculated at 1m into half space.
Reflex loading makes a big positive difference. Open baffle loading
makes an ever increasing negative difference, combined with the
reducing levels available as you go lower it becomes obvious open
baffles (of reasonable size) cannot do low bass at decent levels.
Try WinISDbeta for illustrations of excursion and related max levels.
sreten.
Old 28th October 2007, 02:59 PM   #9
Ron E is offline Ron E  United States
Ron E's Avatar
Some hints, wouldn't want to just give you the answer and spoil the "discovery" for you.
Relation of volume velocity to SPL is perhaps the proper question.
All over the 'net there are equations relating excursion with SPL, and volume velocity (U-m^3/s) is just excursion * Sd * frequency.
In reality SPL is directly proportional to piston acceleration, not velocity.
think of sinusoidal motion.
Excursion:
X(t)=X0*sin(wt)
Velocity = dX/dt:
V(t)=w*X0*cos(wt)
Acceleration = dV/dt:
A(t)=-w^2*X0*sin(wt)
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 29th October 2007, 08:05 AM   #10
Onur's Avatar
During my search for inline passive (before amp.) crossovers I found myself reading this article :
http://sound.westhost.com/qb5align.htm
It would be more scientific to know how the kp (the power output constant) is calculated. Any ideas?
Relationship among T/S Parameters CLS Multi-Way 5 25th April 2008 01:54 AM
Love/Hate relationship with Maggie TexasTim Multi-Way 30 18th September 2007 08:27 PM
A Love/Hate Relationship bulgin Everything Else 18 17th December 2006 06:48 AM
Sealed vs. ported... and what their relationship to BSC is? fjhuerta Multi-Way 0 30th August 2005 04:50 PM
Relationship between Fcb, F(3) and Qtc in a closed box sub Dave Bullet Subwoofers 11 9th January 2002 03:52 PM
Page generated in 0.09391 seconds (86.67% PHP - 13.33% MySQL) with 11 queries
