Old 24th October 2007, 07:45 AM   #1
meistah is offline meistah  Canary Islands
Default My venture into diy home audio
Okay, just was given the first audio related piece of my HT setup today. A nakamichi av-8.
right now its just running a couple "curtis" speakers from a boombox... i will be using them as temporary rears until i get something better.
anyhoo, my plan for the fronts is to use a pair of "Focal 130CA" speakers that i have in my closet. They are 4ohm so the receiver should power them quite nicely, and if I remember correctly they sounded pretty nice in my car.
However, I am unsure how to proceed for building boxes for them.
The specs on their website don't have any detailed information.
I searched around this site and it seems like the recommendation is to do an IB configuration for car speakers... on the other hand I've heard that they will sound nice if i put them in small boxes.
I could send focal a letter asking for the specs, but in the meantime I am curious to hear your guys' suggestions for enclosures.
Old 24th October 2007, 09:37 AM   #2
Plenty of info on the current 130 CA1 here. Should give you an idea of what to expect..
http://www.focal-fr.com/catalogue-do...files/1214.pdf
http://www.focal-fr.com/catalogue-fr...&idProduit=112
These 5" coaxials, manufactured by Focal, were primarily designed for installation in the factory locations of a vehicle, or an infinite baffle arrangement, while taking cabin gain of a car's small interior into consideration. As with many drivers geared toward the mobile market, both Fs (resonant frequency) and Qts are quite high. Aside from that, both on and off axis frequency response is pretty terrible. There are plenty of other reasons not to continue with these plans as well.
With that said, I believe that any attempt to put this driver in an enclosure for use in the home will only end up resulting in a waste of your time.
Apologies if that seemed a little blunt, but that's really just the way it is.
Old 24th October 2007, 09:40 AM   #3
Nanook is offline Nanook  Canada
Nanook's Avatar
Default No Paridigms?
guess not.
please do a search on google, specs came up in the first 2 or 3 listings...
30 litre sealed box recommended by Focal.
stew -"A sane man in an insane world appears insane."
Old 24th October 2007, 09:50 AM   #4
Default Re: No Paridigms?
Originally posted by Nanook
guess not.
no...the seller of the paradigms stopped replying to emails...so im assuming that deal fell through
sorry, I did search on google for box recommendations, and their website said you had to order a brochure, didnt realize you could just download it
well, i think i might just try to do some 1cuft test boxes and see how they sound, in the meantime tho ill keep my eye open for deals on proper ht speakers
has anyone tried Venture Full/Wide Ranger? _henry_ Full Range 3 9th February 2009 06:04 AM
Well, I'm about to venture into my first real DIY home audio project cody6766 Multi-Way 2 26th October 2005 02:08 AM
My first home audio amp. Tim Wyatt Tubes / Valves 9 9th November 2004 08:10 AM
Merging Pro Audio and Home Audio LostInSuburbia Multi-Way 14 22nd October 2004 03:05 AM
Page generated in 0.08361 seconds (75.15% PHP - 24.85% MySQL) with 10 queries
