Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 12th February 2003, 03:21 PM   #1
Cobra2 is offline Cobra2
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Default JBL - L300 mods/updating?
Hello! - please help:
My friend have a pair of the big, old JBL - L300...
and wonder if they can be made "up to date" with
small / careful modifications ???
If you have any experience with these,
please post here!
(and, will it be difficult splitting the filter, for bi-wiring?)
Arne K
NORWAY
Old 12th February 2003, 08:17 PM   #2
diyAudio Moderator Emeritus
roddyama's Avatar
Hi Arne,
You don’t have to split the filter. This is what I would do. Make a new or get a used xover between the LE-85’s and the 077’s and run the woofer right from the amp. I would run a electronic xover for the woofer to horn transition, but you don’t have to.
Cross the LE-85 to the 077’s at about 8kHz or higher if possible. You can frequently find N7000 xovers on ebay, but the N8000 is kind of rare. It may be easier just to make a new xover with premium parts. If you don’t use the premium parts, at least bi-pass the cap with good audio grade caps.
Cover the baffle around the mid-horn and the 077’s with 7mm foam or felt (remove the lens first so the foam goes right to the edge of the horn). Cut strips of the same foam and wedge them between the fins on the rear of the lens, but not more then 10mm in from the back edge. There should be a round area open to the horn mouth. This will help to control any baffle diffraction as the sound wave travels through the lens. Wrap the mid-horn very tightly with some heavy rubber or neoprene. You can use large wire ties to hold the rubber tight around the horn, the more the better.
In the photo, you can see the foam on the baffle and wedged into the back of the fins. You can also see the N7000 which I totally rebuilt with Solen coils and caps. I may eventually replace the L-Pad with fixed value Caddocks.
Email me if you have any questions.
Rodd Yamashita
Old 12th February 2003, 09:17 PM   #3
kingdaddy's Avatar
Your friend is a lucky man; the 300's are IMO the greatest effort JBL has ever made in loudspeakers. I once tried to buy the raw drivers and the tweeters (o77 ring radiator) were unobtainable and over $600 ea. I still have one of the original brochures of this speaker.
Old 13th February 2003, 06:39 AM   #4
frugal-phile(tm)
planet10's Avatar
As well as rubber & duct-tape like Rodd has used, duct-seal works a charm for damping horns and speaker baskets.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
Old 13th February 2003, 06:43 AM   #5
roddyama's Avatar
dave
I know you can't see it in the photo, but there also are a number of muffler clamps under the duct tape
Rodd Yamashita
Old 13th February 2003, 06:56 AM   #6
macka's Avatar
Arne,
Try this JBL link for information about the crossover;
http://www.jblproservice.com/navigat...chematics.html
This will give you a diagram/schematic of the design if you care to update say the capacitors which would improve resolution. Or bi pass the existing caps.
The equivelant in the JBL Pro monitor was the 4333/4333A/4333B.
The latter two versions were biamp version with a switchable crossover. The drivers are identical to the 300, the crossover is number 3133.
I would image the Aleph (Aleph 3 or 5) amplifier on the horn and Slot if biamped would be magic, I currently use the Aleph 2 on my diy 4345 JBL 4 way wth a passive crossoover, its very smooth.
regards
Ian
Old 13th February 2003, 08:40 AM   #7
Norbert is offline Norbert
Norbert's Avatar
Lightbulb Lansing Heritage
Arne,
you will find lots of information about JBL speakers and also about the L300 or 4333 Monitor here:
Lansing Heritage
Lansing Heritage Library
Lansing Heritage Forum
L300 Summit
Best regards,
Norbert
Old 14th February 2003, 05:43 AM   #8
DIY !
Cobra2's Avatar
Default RE:...
Thanx all !
Arne K
Old 14th February 2003, 10:45 AM   #9
Doug is offline Doug
Doug's Avatar
Default JBL L-300
If you get or have access to audioXpress magazine, in the September 2001 there is article called " Resurrecting a Vintage JBL Classic " featuring the L-300. They do a complete rebuild on it.
I have been wanting to get a pair myself to rebuild. A friend of mine back in 1976 bought a pair and they made a lasting impression on me, very quick and powerfull bass. I could never afford a pair back then. If I remember correctly they cost approx $2500.00 per pair Canadian, a lot of cash back then.
DOUG
Old 4th March 2003, 06:31 PM   #10
I've got the L65, the L300's little brother, with the same tweeter.
About the crossover, I must say that replacing the stock caps with mundorf or audyn caps gives a much better, smoother and more detailed sound than simply bypassing the caps, especially to get the grains of the tweeter and the mids.
Also replace the stock inductor on the horn which is probably iron-coiled with a decend aircoil or if you got the money, a tritec or so.
Greets
Thread Tools
Updating Onkyo DX-706? Henrik Digital Source 38 8th June 2009 02:10 PM
JBL L300 for sale stuhaugen Swap Meet 2 25th April 2006 05:46 PM
JBL l300 kekropas Multi-Way 7 9th April 2006 08:53 PM
JBL L300's for sale - Madison,WI RADIOLEE Swap Meet 6 8th September 2003 03:10 PM
Page generated in 0.10181093 seconds (79.36% PHP - 20.64% MySQL) with 11 queries
Copyright ©1999-2010 diyAudio
