Fast, fun, Inexpensive OB project
Old 23rd November 2013, 02:46 AM   #971
Johno is offline Johno  Australia
Johno's Avatar
Very really good. I cannot recommend them highly enough.
I built a pair of the Manzanitas over 12 months ago now so the drivers are nicely run in and the sound and clarity continues to amaze me. Piano sounds nearly like a real piano and the bass notes in Bach's Toccata and Fugue are awesome (pipe organ for those who don't know it).
The only down side is that compression and bandwidth limiting on poor CD recordings becomes obvious. I guess I mean poor digital re-mastering for old stuff especially when compared to the vinyl version.
Plus, a design more sophisticated and expensive would be well past the point of diminished return IMO.
Old 29th November 2013, 02:29 PM   #972
Marinos is offline Marinos  Greece
Marinos's Avatar
Hi John,
I'm ordering parts for your baby Manzi
Is this still valid ?
Originally Posted by John Busch View Post
Manzi crossover tweaks.
L1. You can upgrade to a toroidal (14 Ga, 18.0 Mh PE P/N 255-844) These have tended to measure more like 19.5 Mh. Very expensive, but does provide a touch better dynamics and a bit more woofer efficiency due the much lower resistance.
I can find jantzen C-Core coil in both 18 and 20 mH and in different core diameters.
My questions are
- Should I go with the 18 instead of the 20 mH ?
- In either case larger diameter core is preferable or it's a case where "size doesn't matter"
Concerning the drivers mounting.
I can understand that flash mounting the Vifa it's the way to go.
Is it the same with the Peerless ? Is there any real benefit to do so ?
Marinos
Old 29th November 2013, 06:56 PM   #973
John Busch is offline John Busch  United States
John Busch's Avatar
The 20 MH Iron core is preferable. It provides a bit better control of the Peerless roll off and results in a cleaner over all sound quality in the upper mid range. Please let us know how you project moves along! John
Commercial Website: http://www.manzanitaaudiosolutions.com/index.html
Old 29th November 2013, 07:28 PM   #974
Marinos's Avatar
Thanks John !!
So I'll stick to ERSE Super Q or similar.
What about the woofer mounting ? Does it worth to be flash mounted ?
Marinos
Old 29th November 2013, 07:44 PM   #975
Pano is offline Pano  United States
Pano's Avatar
The Peerless woofer has a sort of tapered flange. I just used that on the front of the baffle. It's made to be that way.
Take the Speaker Voltage Test!
Old 29th November 2013, 08:34 PM   #976
Marinos's Avatar
Thanks Pano,
I'll wait for the drivers and see..
Last question for now is if this is still valid
L2. This component needs to stay put as is. Push comes to shove, 1.5 mh up to 2.25 Mh is way better than nothing. The lower values will brighten things up, the higher will darken the tonal balance. Lower resistance air core inductors do improve midrange quality. I have even tried 8 ga.! However, the modest improvement is hard to justify given the astronomical cost of 8-12 Ga. inductors. The 14 Ga. Perfect Lay air core is a good compromise. 18 Ga. air core and higher Ga. really degrade the effectiveness of the trap as well as the overall sound quality. BTW, stick with air core designs if possible. The speaker will play of course with iron core inductors, but you can hear them. Even 15 Ga. I.C. impart a grain like quality. Have not tried a Toroidal. If I get around to it I will report back.
Should I seek for the best quality and lowest Ga(thus DCR) I can afford ?
Since this choice affects a very important acoustical spectrum the opinion of people that have built the Mazis is most valuable
Marinos
Old 30th November 2013, 07:05 AM   #977
max079 is offline max079  Hungary
Dear All,
I'm new in this topic but i would like to biuld this speaker.
The woofer is already in my hand but the tweeter still missing.
In case that i have left some other tweetersfrom my former project i just thinking to use it.
The tweeter is a Monascor DT254 which looks close in parameters to the SEAS 27TDFC
Could you help me to find out, that this Monacor tweeter are ok for this speaker?
Technical spec:
Impedance (Z) 8 Ohm
Free air resonance (fs) 900Hz
Max. frequency range fx–22kHz
Rec. crossover frequency (12dB) 2kHz
Music power 150WMAX
Power rating 90WRMS
SPL (1W/1m) 92dB
Voice coil diameter 25mm
Magnet diameter 72mm
Mounting cutout 85mm
Mounting depth 38mm
Dimensions 110mm
Weight 0.53kg
DT-254 - Monacor HiFi dome tweeter 150Wmax 8 Ohm - Europe Audio
Thanks,
Peter
Old 30th November 2013, 03:33 PM   #978
John Busch's Avatar
The DT-254 can work.... but it will require a LOT of crossover work and even with that the mid range output is quite limited. My original design using the Seas TDFC required quite a bit of compromise and had a very laid back sonic quality. One of goals at the time was to simply prove you could get a reasonably priced 12" woofer and a 1" class tweeter to work reasonably well together with a simple cross over. The next version using the large (and now VERY expensive Scan Speak D3800 Mid-tweet) was much better and the very low cost Vifa 3.5" full range is better yet. With price and availability of the Vifa 3.5 being so good, I highly recommend you go with that version of the Manzanita.
Old 30th November 2013, 03:46 PM   #979
John Busch's Avatar
Marinos..... Yes... you want a good air core (L2) inductor on the trap. 14-18 ga. will work. As per a previous post, if you go larger wire (smaller ga. #) than 14, your reach a point of diminishing returns. So.... 14 is the best balanced choice if you can do it and it is the inductor the crossover is designed around. Hope this helps. John
Old 30th November 2013, 04:34 PM   #980
Marinos's Avatar
Thanks John
Marinos
Fast, fun, Inexpensive OB projectHide this!Advertise here!
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 09:00 PM
Looking to buy inexpensive... nelsondog Chip Amps 0 15th October 2004 03:04 PM
Inexpensive project, which to choose? manxam Multi-Way 12 28th December 2003 03:51 AM
