Fast, fun, Inexpensive OB project
Old 7th April 2013, 02:55 PM   #871
albertli is offline albertli  Canada
albertli's Avatar
Default POLARITY
Originally Posted by John Bsuch View Post
Please find the current MAS Ultra schematic. Enjoy!
John,
My ultra is coming up soon n the parts from pe is on its way to me. The schematic shows the polarity of the tweeter is inverted - different from the original post. is it the design to date ???
Albert
Old 7th April 2013, 03:28 PM   #872
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Originally Posted by AndrewT View Post
Qts of post867 looks to be very high @ 0.74.
Would that make it very suitable for OB?
Originally Posted by skorpion View Post
... In Europe the budget-choice for OB would be A&D R1524 from: A&D Audio Datenblatt costing 65 EUR today from HIGH-TECH-HIFI. I have compared A&D R1524 to Eminence Alpha15 and Acoustic Elegance IB15 which I have all three and the Alpha15 is by far the worst performer of them. The A&D R1524 was used in my: 'Volks-OB' without EQ and went down to about 40 Hz level.
Played side by side it is striking how similar AE IB15 and A&D R1524 sound giving a tight, clean bass of exellent quality.
/Erling
www.dipolplus.de
Old 8th April 2013, 01:33 AM   #873
John Busch is offline John Busch  United States
John Busch's Avatar
Default Polarity
Albertli
The negative polarity for the tweeter is correct. The phase tracking is better and the current issue of the Vifa driver works much better with the reverse polarity configuration. John
Commercial Website: http://www.manzanitaaudiosolutions.com/index.html
Old 8th April 2013, 03:29 AM   #874
albertli's Avatar
John,
I'm still waiting for the parts, will post pics after finished.
Albert
Old 8th April 2013, 06:01 PM   #875
woodsart is offline woodsart  United States
woodsart's Avatar
Hello everyone,
How about Marantz receivers or particularly the PM8003 2 channel 75 wpc For the original Manzanita? I have a small office room with at least 24" from the corner/side walls.
Thanks!
Old 11th April 2013, 03:27 AM   #876
ruinevil is offline ruinevil  United States
Do the Manzanitas have problems with poorly mastered, overly loud rock and metal?
Old 11th April 2013, 02:57 PM   #877
John Busch's Avatar
Default Marantz & Metal
Marantz 75 wpc receiver. For most listeners, in most domestic environments the Marantz should do just fine.
As for heavy metal music, with 100 clean wpc available, a pair of Manzanita's will deliver about 100 db of peak output from about 40 hz up. Or put another way, about 93-96 db continuous out put at a typical listening distance in a typical residential setting. Suspect that is not enough if you like it really loud!
Hope the above is of some help. John
Old 24th April 2013, 02:58 AM   #878
albertli's Avatar
Default Ultra
My speakers are slowly coming. Hope to put them together in the coming weekend.
Old 24th April 2013, 03:10 AM   #879
Pano is offline Pano  United States
Pano's Avatar
Great! Keep us informed.
Old 27th April 2013, 05:22 AM   #880
surface tension is offline surface tension  United States
surface tension's Avatar
John,
Will you be bringing the Ultra's to LSAF this year, he asks hopefully?
Fast, fun, Inexpensive OB projectHide this!Advertise here!
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 09:00 PM
Looking to buy inexpensive... nelsondog Chip Amps 0 15th October 2004 03:04 PM
Inexpensive project, which to choose? manxam Multi-Way 12 28th December 2003 03:51 AM
