#841 |
Hi
I have one Beyma 18 G550 woofer will it work for the HE? Before I run out and invest in another one I would like to know if it will work out, another thing is that the Beyma I allready have is about 15 years old. I might have used it for about 50 hours at quit low levels. Will it match with a new One? best regards uwe |
#843 |
Here comes an update after 150+ hours with my Ultras. I'm VERY pleased with the performance of the Ultras. I've becomed addicted to the smooth and open sound and the very powerful, low octave bass. I heartily recommend building or buying these excellent speakers from John (Welcome To Manzanita Audio Solutions . Open Baffle Dynamic Speaker Designs).
\Hans in Holmsund, Sweden. |
#844 |
Start my Manzanita.
Attachment 339122 |
#846 |
Hanns....
Thanks for sharing your opinion of the Ultra build! Know it was a lot of work to obtain the GRS in Sweden. I fear a lot of potential builders have difficulty believing how good such a simple design and build can be. And they worry about the intrinsic low efficiency. However, if you run the numbers and measure most designs that can really play flat into the upper 20's, you will usually find one of two outcomes. 1) The enclosure is the size of a double door refrigerator, or... 2) The true efficiency is similar if not less than the Ultra. As best I can measure, the Ultra is around 84-85 dbw. And that is all the way down. No roll-off! Provide a clean 20-40 watts per channel in a typical domestic setting.... for most music, you have more than enough output. Funny thing about the Ultra is the tonal purity of the bass. It's all most creepy to hear true fundamentals with out the usual doubling nearly ALL speakers regardless of design produce below 50 Hz or so. That is why the Ultra low end is SO addictive... as you observered.
Commercial Website: http://www.manzanitaaudiosolutions.com/index.html |
#847 |
John, Pano,
Would you kind enough to point me to where I could find specs n BOM of the Ultra. I'd like to build a pair for myself. Thanks Albert |
#848 |
+1 ... still trying to decide which one to go for
Lighten up while you still can ... |
#849 |
Albertli: BOM for the Ultra is on The best affordable DIY open baffle loudspeaker I've listened to so far. and the design/crossover is on the next page. The components at PE now cost $208... with the wood being extra.
Pano, John: The 20mH inductors are backordered at PE. Any replacements? |
| How fast are 'Fast Fuse' and how to identify? | bigpanda | Solid State | 7 | 22nd March 2005 09:00 PM |
| Looking to buy inexpensive... | nelsondog | Chip Amps | 0 | 15th October 2004 03:04 PM |
| Inexpensive project, which to choose? | manxam | Multi-Way | 12 | 28th December 2003 03:51 AM |
