Fast, fun, Inexpensive OB project - Page 82 - diyAudio
Old 20th September 2012, 11:17 PM   #811
Moondog55's Avatar
Perhaps a new homage to Briggs is due?
15 PLUS 10 or 12 with 15 rolled off first order and taking on some of the low bass, crossing a 10 to a 3 should be easier.
This is the project i have had in the back of my mind ever since the start of this thread, mainly because I have a 15" driver that isn't usable in anything other than an OB design
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 28th September 2012, 08:00 PM   #812
todd is offline todd  United States
What do you guys think about one of the new Visaton drivers P.E. is getting now:
Visaton 9069 W300 12" Woofer 8 Ohm 292-588
or even the 10":
Visaton 9067 W250 10" Woofer 8 Ohm 292-586
in a Manzanita-style speaker?
They seem like they're a little less expensive than the go-to peerless driver.
They also have an interesting looking F.R. coming in Nov:
Visaton 3017 BG17 6.5" Full-Range Speaker with Whizzer Cone 292-546
Old 28th September 2012, 10:48 PM   #813
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
or even the 10":
There is no doubt that the comparable Peerless SLS drivers are better value for money - even at twice the price. But if you really are on a budget, a pair of Visaton W250 mounted in a H frame can be a very reasonable start into OB bass.
www.dipolplus.de
Old 28th September 2012, 11:00 PM   #814
Moondog55's Avatar
PE data is wrong on one aspect, X-Max is 14mm in total ( +/- 7mm )
if you modeled giving 14mm X-Max you would get the wrong results
Old 28th September 2012, 11:10 PM   #815
Moondog55's Avatar
Not suitable for the Manzanitas but cheap intro to OB could be a quad of these
10" Ribbed Treated Paper Cone Woofer Speaker 299-283
Old 2nd November 2012, 11:55 AM   #816
AndrewT is online now AndrewT  Scotland
I'm going to build a couple of iron core inductor from reclaimed microwave oven transformers.
The Is were welded on to the Es all on one side, so easy to dismantle and easy to insert an air gap in the legs when reassembling.
I will "test" the wound inductor by applying a frequency to a series combination of a resistor and the inductor.
Q.
at what frequency should I test for 20mH?
50Hz or 200Hz or somewhere in between?
What about the 2mH inductor? Should it be tested at a higher frequency? 500Hz, 3kHz?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 2nd November 2012, 01:03 PM   #817
Pano is offline Pano  United States
Pano's Avatar
Good question. My LC meter tests at 400Hz, one would hope that inductors built for the audio range are linear (enough) thru the audio bandwidth.
What really matters is the impedance vs frequency, since that is how it's used in a crossover.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 30th December 2012, 09:49 PM   #818
liasom is offline liasom  United States
liasom's Avatar
Default Peerless 830669 on sale at Madisound
Noticed that the Peerless 830669 is on sale at Madisound for $79.90 each + shipping. But since PE has free shipping the deal may not be so good depending on location. Maybe PE would match pricing? To my zip in TX the total would be around $10 cheaper from Madisound. YMMV.
Peerless 830669 at The Madisound Speaker Store
Mike
"Twelve." --Dr. Nikolai Zubritsky
Old 31st December 2012, 12:01 AM   #819
Johno is offline Johno  Australia
Johno's Avatar
What really matters is the impedance vs frequency, since that is how it's used in a crossover.[/QUOTE]
Impedance vs both frequency and current for an iron core.
I am building air cores and have wound the first 20mH. About 5kg and beautiful. Still soaking with the varnish so not quite ready for testing, and now that the festivities are over, no more interruptions. Also finished a 2mH but the moment I loosened the bobbin it went 'sproing'. "Drat" I said.
Ended up building a winding machine from scratch using a windscreen wiper motor with a homemade pulse width modulated speed control - the only way I could get enough torque to properly tension the heavy wire.
Old 31st December 2012, 03:29 AM   #820
Pano's Avatar
That's cool, would love to see pix.
What the DCR going to be on an airecore 20mH?
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 09:00 PM
Looking to buy inexpensive... nelsondog Chip Amps 0 15th October 2004 03:04 PM
Inexpensive project, which to choose? manxam Multi-Way 12 28th December 2003 03:51 AM
Copyright 1999-2017 diyAudio
