Fast, fun, Inexpensive OB project
Old 16th December 2009, 11:49 AM   #201
Telstar is offline Telstar  Italy
Originally Posted by heinz1964 View Post
hi
Anybody tried with a 3" or 4 " fullrange yet?
I think a 4" fullrange will never have enough xmax to be used in open baffle.
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
Old 16th December 2009, 01:53 PM   #202
Pano is offline Pano  United States
Pano's Avatar
There has been a little experimentation, but not much. I think it's a good idea, if the right driver can be found.
Take the Speaker Voltage Test!
Old 16th December 2009, 03:35 PM   #203
I heard 2x 6" (tangband or fostex i think) and they were very nice at low to moderate SPL.
Old 16th December 2009, 03:45 PM   #204
nhjsdfops is offline nhjsdfops
Old 16th December 2009, 03:50 PM   #205
Jonasz is offline Jonasz  Sweden
Jonasz's Avatar
I'm sure a fullrange driver will have enough xmax to replace a tweeter...
Old 16th December 2009, 04:05 PM   #206
Godzilla is offline Godzilla  United States
Godzilla's Avatar
Several on this forum seem to be using 4" Fostex drivers on OB with success... i can't seem to cut the holes to mount the drivers for fear it just won't work but maybe i should just try it and see for myself. I have a pair of Fostex 127e and TB Bamboos but they are in use at the moment. I also want to try the 6" Fostex 165k and 168z on OB... but they work so nicely in BIBs and ported boxes... The Betsy 8" works well on OB but it's designed for that.
Godzilla
Old 16th December 2009, 04:17 PM   #207
human.bin is offline human.bin  Italy
is the Qts of a driver the only parameter telling its suitability for OB?
otherwhise, does a driver need something special to be OB when you are using it over 200hz??
i remember Gainphile tried the TB bamboo on his blog and was disappointed on farfield listening, hopefully he will chime in.
everybody seem delighted by the FF85k which should be around 90db sensitivity.
Old 16th December 2009, 05:50 PM   #208
MikeHunt79 is offline MikeHunt79  United Kingdom
MikeHunt79's Avatar
Hi, I know of 2 different 3" drivers that have 3mm of one way xmax. Not a massive amount, but quite a bit for a 3" driver. I think these would give quite a bit of output from 1KHz+.
Old 16th December 2009, 06:32 PM   #209
If we are talking 1khz and up, then yes, why not? (although not my cup of tea )
But I thought the idea was to go lower like 500-600hz.
Old 16th December 2009, 06:38 PM   #210
Jonasz's Avatar
500-600hz should not be a problem either...
Fast, fun, Inexpensive OB projectHide this!Advertise here!
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 09:00 PM
Looking to buy inexpensive... nelsondog Chip Amps 0 15th October 2004 03:04 PM
Inexpensive project, which to choose? manxam Multi-Way 12 28th December 2003 03:51 AM
