Woofer in 3-way system. I have looked a lot of 3-ways, but I am not sure what would be good F3 for woofer. The woofer I am gonna use is Dayton RS225
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=295-366
Fs 29Hz, but should I go so low?! Have any clue. Does this sound already to boomy. What F3 you suggest for these drivers.
Most 3-ways are around 30-45Hz. How I should decide what F3 to choose.
Music I am listening is more pop, 80-90 and also even I like to listen piano (classic).
If you want to use your speakers whithout a (min. rek. 2pcs.) sub, you should at least go for flat down to about 30Hz in room, witch these drivers should be able to achieve (albeit with low sensitivity).
I am not gonna use Sub.
Then could you answer, why some really good speakers have done F3 45Hz?!Even when woofer are able to go 30 at least.
http://www.audes.ee/?id=1880&tpl=1020
R:R
R:R
Perhaps to minimize group delay? Or the port simply became too long? Engineers trading performance for aestethics (Smaller cabinet.)? Perhaps the F-3dB@45Hz is in free space? In a room, you get some help in the lowest frequencies.
