Old 19th October 2007, 08:34 PM   #1
Default power handling
What is the proper way to calculate a speaker system’s (three way or two way speaker system) power handling when the drivers used have different maximum power values?
Also, is it appropriate to place a resistor in the speaker systems circuit path to raise the impedance to an “ideal” level for the power amp’s output stage? Is there another design approach? What will result in the least amount of distortion? What is ideal? I’ve noticed that most DIY home audio drivers are rated at 8ohm. When connecting a pair (whether parallel or in series) to make the system into a two way speaker system you get a value that wouldn’t suite the amp I have.
Please reference your response.
Old 19th October 2007, 11:57 PM   #2
Ron E is offline Ron E  United States
Ron E's Avatar
Default Re: power handling
Destructive testing. Power handling specs are mostly smoke and mirrors anyway. Are you building PA speakers, or speakers for the home? A rule of thumb for pop music might be equal power per octave from 40-8kHz Tweeters are generally "system" rated at a particular crossover point. Many tweeters can be blown with a 3 to 6 Volt sine wave across the terminals.
Not generally, no.
Ideal is having speakers with the right impedance. Most amps don't care if the impedance is high, though, so series may be your best option. Ohm ratings on amplifiers are mostly only important if you listen at high levels or have REALLY cheap amplification.
You could use an autoformer, but for solid state amps you need a blocking cap because an autoformer is a DC short and SS amps tend not to like that....
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Speaker Power Handling 69stingray Multi-Way 5 3rd November 2007 08:27 PM
Tweeter power handling ? youyoung21147 Multi-Way 29 4th May 2007 01:53 AM
Power output vs speaker power handling Bob0513 Chip Amps 4 5th November 2006 11:41 AM
TL Power handling fortyquid Multi-Way 9 13th October 2003 01:18 AM
Power Handling Myren Multi-Way 1 30th October 2001 08:18 AM
Page generated in 0.07131 seconds (70.90% PHP - 29.10% MySQL) with 10 queries
