#41 |
I bought a used Proac Studio Tower a while back - which uses the ATC mid (16ohm - non-s version), the SB75-234 LC version and a SS tweeter.
It sounded pretty good, but my plan was to clone the ATC 50 (passive version). I bought the Seas tweeter ATC use (T25-003) and re-constructed a heavy front baffle with the driver orientated as ATC had them (offset mid/tweeter to the bass driver). Anyway, I did not mess around with the xover between the bass and mid (kept the original Proac design) but obviously had to modify for the new tweeter. I am still in process... but it sounds great! The bass setup is a bit odd as the Proac design is based on a EBS design - which tends to be a natural sounding, but a little light weight. For interest sake (I am always interested in designers who use ATC) a local company here in Ottawa has released a speaker using the ATC mid and a Mundorf tweeter! http://www.tetraspeakers.com/pages/606.html Thet say they cross it over at 1K!?!? Insane! (or it's a typo). And yes - they are using the S version. |
#42 | |
The more you know who you are and what you want, the less things will ever be the same. |
#43 |
I haven't heard the atc yet but some tell me it's dynamic fast loud but is it musicaly rich?
does it tend to be lean because of the dynamics? i was suggested the atc and the raal tweeter by solen,with the eton 11"x2, does anybody know what kind of xover slopes i will need? |
#44 | |
The ATC mid plays what's on the recording, it doesn't suffer junk recordings. So its only musically rich when the source material is. 3-3.5Khz 4th order would work OK with the little RAAL 70-10 and 500hz highpass is the best place to start for lowest distortion on the ATC.
#45 |
lol
I'm not so good in describing music. i know what you mean if the recording is good,and what i mean when the recording is good sometimes i heard speakers sound thin not rich like the good recording was on other speakers. i hesitate on the mid AT 5" or 6"or the ATC for that richness...but saw that your preferance was the atc like a lot of others here in the forum...
| xover for atc sm75-150s | montana | Multi-Way | 2 | 8th July 2007 05:25 PM |
| Fs: Atc Sm75-150s | triode4 | Swap Meet | 1 | 7th September 2006 01:55 AM |
| FS: ATC SM75-150S midrange domes | Jussi | Swap Meet | 3 | 20th January 2006 10:51 AM |
| FS: ATC SM75-150S midrange domes | Jussi | Swap Meet | 1 | 20th January 2006 08:50 AM |
| wanted : ATC midrange SM75 150S | Vil | Swap Meet | 0 | 15th March 2005 07:39 AM |
