Lower midrange for ATC SM75-150S
Old 19th October 2007, 07:33 PM   #11
ShinOBIWAN is offline ShinOBIWAN  United Kingdom
ShinOBIWAN's Avatar
Direct from ATC or Solen in Canada
The more you know who you are and what you want, the less things will ever be the same.
Old 19th October 2007, 07:44 PM   #12
thadman is offline thadman  United States
I'd like to use a 15, but am a little hesitant using one up to 600hz. at 600hz, the wavelengths are about twice as long as the cone diameter (which would suggest omnidirectional behavior)...am I forgetting anything? One of the main goals of this build is smooth power response, and I do NOT want to sacrifice it for low end. Do they have the output, dynamic range, and distortion performance of dual smaller midranges (8-6") in the midrange and midbass (ie 100/150hz to 600hz). The Aurasound is fully capable of crossing as high I'd need it, so sensitivity (and power compression) is favored in fair of sheer volume displacement.
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them."
Old 19th October 2007, 08:30 PM   #13
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
This is not going very good ... are we forgetting that he is aiming at the "S" version ATC ... 95db ??
And please forget about crossing the Aurasound "as high as you want" ... maybe so from specs and graph, but reality may be much different
Old 19th October 2007, 09:32 PM   #14
As high as I'd like for a subwoofer. I'm sorry I should have been more specific. Most high inductance subs don't like being taken over 60hz. This driver should have NO problem tackling 250hz, thus I concluded that it'll go as high as I'd ever want or need.
Old 19th October 2007, 09:35 PM   #15
There is a certain myth around the ATC mid, but to be honest it dont impress me THAT much ... BUT the possibility of 95db sensitivity makes it an interesting candidate
You dont seem to like any 10-12" PA drivers ? ... I dont see there is any way around them
Old 19th October 2007, 09:40 PM   #16
What have I said that led you to believe I dislike 10-12" PA drivers? The Aurasound is going to be used as a subwoofer, I have no plans for crossing it to the ATC midrange.
I've found no better subject evaluation of a true midrange. I'm aware that it is not a midwoofer and plan on crossing it accordingly, thus the reason for this thread.
Old 19th October 2007, 10:21 PM   #17
What about the 18Sound active impedance control units (12NdA520 and 10NdA520). They are both much cheaper ($230/each) than the $800 ATC speakers, have low distortion and high efficiency.
Old 19th October 2007, 10:27 PM   #18
Ok, yeah I was a bit quick on that one ... only possible to edit fore a short while, so must be carefull with the words
I am looking into a high SPL 3way and am narrowing it down to either 15" or 18" woofer
Using a sub makes 10-12" woofers a better option ... yet there may be a question of how much BSC you will need ... I suppose with bigger woofers less BSC is needed
You dont want to loose too much of the ATC sensitivity ... so if some BSC is needed you might end up with a 12" or maybe even double 10" woofers
Unfortunately many interesting and effektive 10-12" midwoofer dont seem to have much lowend ... yeah, double 10" might be the way, allthough I am not keen on using two drivers playing the same frequency
Just thoughts, please go on
Old 19th October 2007, 10:47 PM   #19
I'm going active with pro amps, so sensitivity will not be compromised.
Old 19th October 2007, 10:52 PM   #20
Does that mean that you will be able to give midbass amps exstra gain ... HOLTON is making such a thing and SKA makes active xo with possible exstra gain (could stress the driver) ... or else attenuating the mid will result in loss of sensitivity and it will all be for nothing, or am I missing something
18Sound active impedanse control unit ???
Lower midrange for ATC SM75-150SHide this!Advertise here!
xover for atc sm75-150s montana Multi-Way 2 8th July 2007 05:25 PM
Fs: Atc Sm75-150s triode4 Swap Meet 1 7th September 2006 01:55 AM
FS: ATC SM75-150S midrange domes Jussi Swap Meet 3 20th January 2006 10:51 AM
FS: ATC SM75-150S midrange domes Jussi Swap Meet 1 20th January 2006 08:50 AM
wanted : ATC midrange SM75 150S Vil Swap Meet 0 15th March 2005 07:39 AM
