Old 19th October 2007, 01:07 AM   #1
Llana is offline Llana  Spain
Default ATC transducers in dipole loudspeakers?
Hello, I'm Jorge.
Anybody utilize ATC SM75-150 drive units in dipole loudspeakers project?. If somebody use these transducers I'd like to know the quantity and the arrangement in each baffle.
For example:
- One transducer per baffle.
- Two transducers per baffle in symmetrically arrangement.
- Four transducers per baffle in quad array, like the midranges in the Helix loudspeakers of Legacy Audio, ( yes, I know that Legacy don't use ATC).
I imagine that the use of four SM75-150 per loudspeaker sound like a madness.
Old 19th October 2007, 02:09 AM   #2
wigginjs's Avatar
Default Re: ATC transducers in dipole loudspeakers?
Only to the weak.
The Four Chairs
DIY Home Theater
Old 19th October 2007, 02:57 AM   #3
ShinOBIWAN's Avatar
The ATC SM75-150 and its bigger brother SM75-150S are both closed back designs much as you'd find with a dome tweeter. You won't get any dipole happenings with those unless you duplicated the quad ATC array on the rear of the baffle.
The mid drivers alone will set you back over $12k.
Now where did I put that spare kidney...
Old 19th October 2007, 03:13 AM   #4
el`Ol is offline el`Ol  Germany
Why shouldn`t one love the boxless bass of an OB without the hyper-airy dipole sound?
I am asking myself whether the ATC could be integrated in MJK`s concept.
http://www.quarter-wave.com/General/OB_Design.pdf
The highpass cutoff is 400Hz, good for the ATC, but would 12dB be steep enough?
But someone who can afford 8 ATCs will probably go DEQX anyway.
Dipole Ribbon tweeter isolation from dipole mid-woofer array Bent Planars & Exotics 5 21st May 2009 12:10 PM
Transducers lpoht Multi-Way 8 14th May 2007 12:19 AM
FPS transducers - what to do with them? Spasticteapot Planars & Exotics 14 6th December 2006 11:40 PM
Tactical Transducers punkrokr1701 Everything Else 6 6th November 2006 10:24 PM
Tactile Transducers seangoesbonk Parts 2 3rd July 2002 12:13 AM
Page generated in 0.07380 seconds (74.08% PHP - 25.92% MySQL) with 10 queries
