Old 18th October 2007, 10:26 AM   #1
kaan is offline kaan  Denmark
Send a message via MSN to kaan
Default Modification of a driver
I found this article describing the modification of a scan speak driver and while I find it very interesting I am not sure that I have the guts to try it myself.
Is there any of you that have tried this or similar modifications?
If so please provide links and stories
http://www.steenduelund.dk/scanspeak8554.pdf
Old 18th October 2007, 05:50 PM   #2
Speakerholic
Cal Weldon's Avatar
We get to see a lot of the phase plug, bucking magnet and cone treatment here but the thread spider is a new one to me. Very interesting.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 18th October 2007, 06:11 PM   #3
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
I'm confused. There's no strain relief (ie the wavy shape of a spider surround), so I would expect a thread to snap at high excursion, which would likely destroy what's left of the speaker.
I would say that if the frequency response and/or Q values of the driver you have aren't what you want, find another driver rather than doing a bunch of scary modifications.
Old 18th October 2007, 07:42 PM   #4
sdclc126's Avatar
I agree - especially since the current stuff from Scan Speak is so good.
While we're on the subject, does anybody know why SS doesn't use phase plugs? I don't think I've seen any of their drivers with them. Most of the top end makers use them in at least a portion of their product lines.
Soft Dome
Old 18th October 2007, 08:41 PM   #5
tinitus is online now tinitus  Europe
10 years ago I replaced spiders with threads on a SS 6" and phase plugs too ... no big deal ... and didnt help the driver much
BUT lately I have removed dustcaps on SS 8" woofers in a 3way ... no phaseplugs this time but new dustcaps made of airy foam ... great improvement from the bottom to the top
Whenever possible mr. Duelund used half a tabletennis ball as dustcap ... one reason why the SS 15W looks like that ... but others have used very round dustcaps before ... but please, mount it where the voicecoil is joined to the cone and nowhere else
I am building my own 6" driver at the moment ... and now a "thread-spider" comes in handy
Old 18th October 2007, 11:08 PM   #6
Ron E is offline Ron E  United States
Ron E's Avatar
Ok, so he made a driver with a looser suspension.
Big Deal. It looks like a recipe for driver failure. Model any driver and change Cms, note what happens.
I bet it distorts more than the original driver and sounds different. Seems like a classic case of I-did-it-itis -- doing something and deluding oneself into thinking it made it better.
The flow diagram shows vortex shedding, not solitons. Vortex shedding, being a velocity sensitive effect, doesn't depend on pressure so much, as described in the text, especially since sound pressure is a gnat on an elephant's bum compared to the 101325 Pascals of atmospheric pressure. The whole writeup is moronic and ill-justified - bonehead audiophiles will believe anything vaguely scientific if it comes from a "known" entity....
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 18th October 2007, 11:14 PM   #7
sdclc126's Avatar
So how do you REALLY feel about it, Ron?
Soft Dome
Old 18th October 2007, 11:21 PM   #8
I should ad that he often worked on improving carefull selected and quite cheap drivers
Its just as big a delusion as to think that a driver is as good as can be just because it comes from a well reputed compagny ... or because its expencive
At one time he modified a CerwinVega to such a degree that it was the best many people had ever heard
Old 19th October 2007, 12:04 AM   #9
Magura is offline Magura  Denmark
Magura's Avatar
Well, if you pay attention to what Duelund has made over the years, you will see that is't best described as hit and mis backed with loads of hooey.
No offense meant, but you should take his "papers" for what they are. I recon he has made a few things that actually worked, but most of the stuff he played around with were a real far fetch.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 19th October 2007, 12:26 AM   #10
Speakerholic
Cal Weldon's Avatar
I once cut out sections of the spider of a couple drone cones to get them moving a little better and further but threads seem a bit suspect to me.
Driver modification query Moondog55 Multi-Way 19 15th February 2009 11:40 PM
Modification..... Actuary Tubes / Valves 3 26th February 2008 01:34 AM
any modification can be done for speaker Driver protection using LM3886 rhythmdiy Chip Amps 0 23rd October 2007 06:16 PM
X-over modification hermanho Multi-Way 1 20th February 2006 06:52 AM
driver modification - extreme? tinkerbell Multi-Way 3 29th March 2005 10:29 PM
Page generated in 0.10586 seconds (82.76% PHP - 17.24% MySQL) with 10 queries
