Old 17th October 2007, 06:42 PM   #1
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Question Biwiring/biamp question..
Hi all,
I have a simple and quick question;
I have a pair of Wharfedale Diamond 9.6.. If I use biwiring and also biamping, every channel makes 8 ohm or 16 ohm?
Thx.
Best regards,
Ozgur
Old 17th October 2007, 08:22 PM   #2
Hi Dxvideo, if you bi-amp or bi-wire the impedence should remain the just the same as the speakers were originally.
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse.
Old 17th October 2007, 08:53 PM   #3
audiobomber's Avatar
Default Re: Biwiring/biamp question..
Originally posted by Dxvideo
Hi all,
Thx.
Your Wharfedales are a nominal 6 ohm load, so that's what they will be after biamping.
Dan
Old 18th October 2007, 06:39 AM   #4
Dxvideo's Avatar
No... I mean,
When they were connected via a single cable, the bass/midbass and mid/tweeter channel was paralelled. And when I connect them as biwired then they are nomore paralelled. So the impedance must be decreased. Am I right?
Best regards,
Ozgur
Old 18th October 2007, 06:48 PM   #5
No... I mean,
No, they're still connected in parallel. You break the parallel connection at the speaker terminals, and you re-make it at the amp (or amps if you're bi-amping). It's the same load.
Dan
Old 18th October 2007, 07:29 PM   #6
peter_m is offline peter_m  Canada
If you connect two loads on a single amp in parallel ... the resistance is calculated as follows, where your loads are a and b and the total calculated is T
1/a + 1/b = 1/T
according to this, a nominal 6ohm speaker, once the paralle connection is broken and it is powered by two separate amps, the load should be a proximately 12 ohm on each component of the speaker.
Old 18th October 2007, 08:15 PM   #7
1/a + 1/b = 1/T
If it was DC I could see that, but it's AC, so the impedance at any given frequency will be the same, whether it's biamped or a single amp.
Dan
Old 18th October 2007, 08:30 PM   #8
Did it Himself
richie00boy's Avatar
1/a + 1/b = 1/T
But they are not connected directly in parallel because of the crossover.
The correct answer as Jonathan Bright said is that the impedance remains the same (to all intents and purposes) as it did before the biwiring or passive biamping.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
simple biamp question mrkramer Chip Amps 7 27th March 2009 10:57 PM
I have a question about the biwiring.. haggy Multi-Way 69 24th April 2007 05:30 PM
What is biwiring? anders.a Solid State 28 4th April 2006 09:28 AM
To Biamp or not to Biamp, that is the question??????? Apogee Pass Labs 70 12th July 2002 12:34 AM
Page generated in 0.09685 seconds (77.97% PHP - 22.03% MySQL) with 10 queries
