Old 15th October 2007, 08:46 PM   #1
weinstro's Avatar
Default Tweet, tweet!
Hi All,
For my paper tiger, I'm having some difficulty picking between the Seas T25CF001, 27TDFC, and Peerless 810921. All appear to be fine, low distortion tweeters.
When might you pick the T25CF001 over the others? How about the 810921?
My paper tiger is an MTM with 5" mid-bass drivers. I will need a low-ish crossover frequency.
Thanks for your insights!
Old 16th October 2007, 12:18 AM   #2
badman is offline badman  United States
Custom Title
badman's Avatar
Default Not too relevant but
I use the peerless in a 3 way , practically as a supertweeter. No complaints here, sounds fantastic.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 16th October 2007, 12:42 AM   #3
Jay_WJ is offline Jay_WJ  United States
I was basically in the same situation when I looked for a tweeter for my Usher 8945P 2-way design. I needed one that has the lowest possible distortions down to 1 kHz because I wanted to cross it at 1.5 kHz. Also looked for one under $100.
My choice was the Peerless 810921. But I would've chosen one of the following and be happy with the result:
- Dayton RS28A-4 (Zaph's tested sample was from the problematic initial production batch; since then the problem was corrected)
- Seas 27TBFC/G
- Seas 27TDFC
I'd not look at the T25CF001. It's an old design and has been discontinued (maybe some are left at Madisound). Zaph tested it and found that distortion performance was not as good as the Seas Prestige below 2 kHz.
Old 16th October 2007, 01:12 AM   #4
fpara is offline fpara  Canada
I'd go 810921 as well
Old 16th October 2007, 10:01 AM   #5
banana is offline banana  Hong Kong
Wouldn't 27TDC better than 27TDFC??
27TDFC appears to have higher distortion around 5~7KHz, both from Zaph's and Mark's test. Though I don't know how bad this distortion will affect the sound.
Old 16th October 2007, 01:57 PM   #6
Just looked at Mark's test. It won't affect the sound since it's above 20 kHz.
Old 16th October 2007, 04:29 PM   #7
sreten is online now sreten  United Kingdom
Default Re: Tweet, tweet!
the best tweeter will be the one with the best crossover,
http://www.eldamar.net/audio/RS150MTM/ /sreten.
Old 19th October 2007, 06:28 AM   #8
weinstro's Avatar
Thanks for the advice. I was concerned that the 810921 couldn't crossover particularly low.
Old 19th October 2007, 09:29 AM   #9
nicoch58's Avatar
HI
yes the xover sinergy whit woofer ,ie phase,ecc... make the difference
To tweet or not to tweet? pforeman Full Range 2 7th April 2009 07:30 PM
Temp setup: BEST MID AND TWEET we can buy ? JinMTVT Multi-Way 65 29th November 2006 12:49 PM
Please help me identify this tweet!!! safetyman Multi-Way 2 18th December 2005 06:33 AM
Anyone measured the PE 269-788 Tweet? SmarmyDog Multi-Way 0 1st October 2005 05:18 PM
Page generated in 0.09436 seconds (76.58% PHP - 23.42% MySQL) with 10 queries
