Old 15th October 2007, 07:21 PM   #1
Default 3-way studio monitor design opinion?
Iam planning to build a 3 way active studio monitor.
I am planning as the following...
tweeter >> SS 9700 ( 3000+ Hz)
midrange>> SS KEVLAR MIDRANGE 13M8636 (400-3000Hz)
Woofer >> vifa PL 26WR09 4ohm( < 400Hz)
amps>
2 LM3886( parallel ) for tweeter
2 LM3886( parallel ) for midrange
4 LM3886( parallel ) for woofer
preamp and active crossovers with LM4562
any suggestions my friends?
Old 15th October 2007, 08:52 PM   #2
Is this monitor going to be a real studio monitor for recording purposes?
Old 16th October 2007, 01:27 AM   #3
yes
Old 16th October 2007, 07:32 AM   #4
Are you already familiar with speaker building?
Here are my thoughts on what helped me:
1.) I would go for constant directivity, since waveguides are really hard to build for DIY. If I had the possibility, I would go for an inwall or "almost-inwall" (flat box mounted at the wall) speaker. However, results will only be good, when you can sit in the or at the reverbradius of your room.
2.) alternative: if speakers can be placed into the room, I would consider to built a true dipole strongly. Due to the radiation pattern, you will gain a factor of 1.83 for your listening distance. However, edge reflection will become a problem.
For the driver selection:
In case of 1.): almost all cones tend to break up significantly at frequencies 1.5 times their cricumference resulting in possible audible "horn" artefacts and an increased directivity, therefore, in order to cross higher M to T, I would either use a smaller midrange cone or a 3'' midrange dome. Although it is not popular, but for a constant directivity, do not cross a 10cm mid or a 3'' dome higher than 2500. The midrange will most likely be the most important driver for your "color" and neutrality.
I would see not point using the scanspeak tweeter. You do not need a driver with low crossover potential. I would strongly consider the peerless hds driver.
In case of 2.): I haven't completely thought through that...
Have fun
Leif
3-way studio monitor design recommendation rhythmdiy Multi-Way 13 15th August 2008 10:10 AM
Bi-Amp Studio Monitor Design makarand_g Chip Amps 3 14th August 2008 12:11 AM
studio monitor ... Ahmad_tbp Multi-Way 27 15th September 2006 08:46 AM
Studio monitor gev Instruments and Amps 30 17th January 2006 07:53 AM
DIY studio monitor mgoedeke Multi-Way 4 22nd June 2003 03:29 AM
Page generated in 0.08075 seconds (72.19% PHP - 27.81% MySQL) with 10 queries
