Old 15th October 2007, 05:21 AM   #1
el`Ol is offline el`Ol  Germany
Default Manger vs. F200A - sick experiment
Hello all!
I have an idea for a sick experiment: Put Fostex F200A and Manger in a box with 6dB active x-over and see where, subjectively, is the best x-over point. Will the Manger end up as supertweeter? Or the Fostex as subwoofer? I didn`t post this in the fullrange forum because one could end up with a conventional woofer/tweeter setup, just crossed flatter. What do you think, what would be the result?
I don`t assume anyone has the two lying around.
Currently I am not sick enough to do the test, but this may change. And whatever would be the outcome of the experiment, one could build a really nice box with one-cap-one-coil x-over at the end.
Greets,
Oliver
Old 15th October 2007, 05:32 AM   #2
Jeez, aren't those Manger driver expensive?
I think I recently came across something saying 500 and something each, and I think it was EUR or GBP, which would be either $700-$800 USD, or $1000-$1200 USD. Anybody have any idea?
Old 15th October 2007, 05:33 AM   #3
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
Default Re: Manger vs. F200A - sick experiment
the are where both drivers will operate fairly wll (300Hz to 3000Hz) mean that you can have almost no crossover maybe just a simple cap for the manger.
...still looking for the holy grail.
Old 15th October 2007, 10:50 AM   #4
Why does anyone want to do this ? What is the advantage of having "almost no crossover" ?
Charles
Old 15th October 2007, 01:56 PM   #5
sdclc126's Avatar
Charles
The advantage is, if it isn't necessary you save money and build complexity.
Soft Dome
Old 15th October 2007, 02:14 PM   #6
If you don't need any crossover and just ONE driver I see where you can save money.
But if you use TWO expensive (almost fullrange) drivers with ALMOST NO crossover (= different to NO crossover) then you won't save anything.
You then better use a good woofer (much much cheaper than each of these two) paired with either one of these fullrangers.
This thingie would then be a FAST system, i.e. Fullrange And Subwoofer Topology (OK - the use of the therm sub is a little exagerated).
You could even use a simple transient-improved active crossover with this arrangement.
Charles
Old 15th October 2007, 03:56 PM   #7
sdclc126's Avatar
"...if you use TWO expensive (almost fullrange) drivers with ALMOST NO crossover (= different to NO crossover) then you won't save anything."
If you use the two drivers with "almost no" crossover as opposed to the same two drivers with "more" crossover than necessary then you are still saving cost and complexity - that's all I meant.
Cheers
Soft Dome
Old 15th October 2007, 04:15 PM   #8
Agreed, but normally no one uses both these drivers together WITH a crossover to start with - only to end up with a more expensive solution than using either one together with a woofer. The latter would not only be cheaper but it would offer better quality as well.
Charles
Old 15th October 2007, 04:18 PM   #9
Don`t understand me wrong, I would only see it as a really successful outcome if it would turn out that the ideal x-over frequency is somewhere in the middle. The Fostex as subwoofer or the Manger as supertweeter would also in my eyes be a waste of money.
Old 15th October 2007, 04:19 PM   #10
But why do you want to split a range into two parts that either driver can manage equally well ?
Charles
Sick Carver M-1.0t amp: bad caps? sblack6 Solid State 1 7th June 2009 08:53 AM
Got this on this on ebay..sick amp benny_rx_blanco Car Audio 2 8th April 2009 11:18 PM
New sick amplifier Solosound Car Audio 3 5th December 2008 02:29 AM
My Fender 6G15 is sick bassman314 Instruments and Amps 8 29th January 2007 03:54 PM
Help - Z4 sick on startup BeaufortRalph Pass Labs 5 18th April 2005 07:50 PM
Page generated in 0.10559 seconds (82.00% PHP - 18.00% MySQL) with 10 queries
