So I need to remove tweeter cone. It has 4 torx.
Is it dangerous to remove the cone or how its works. I tryed to search also from internet. Tweeter is 810921. |
#2 |
It is kinda hard to understand what you are asking... do you want to remove the tweeter from the box (in which case thwe torx screws would make sense) or remove the cone from the tweeter.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Nope the torq screws holds the flange ontop of the peerless.. no idea what it looks like inside...
http://www.tymphany.com/datasheet/printview.php?id=170 |
#4 |
When he said tweeter cone, i of course thot of a cone tweeter.
On these dome tweeters, the 2 bolts come out so you can remove the bezel, and then you can get at the tweetr "butterfly". This assembley has the dome, the voice coil, and lead-out wires (and often the solder terminals, mounted on a structure that holds the whole thing together & aids getting the dome properly aligned (i can take pics if needed0 dave
#5 |
What I meaned was that how to remove the tweeter dome with this metal plate. So there bare 4 screw. What i tryed to ask is how easy it is to remove this dome together with metal plate and how easy is to put it back. F.E when you want to do some tuning of tweeter etc.
R. |
#6 | |
I have at least one unit here i could take apart & put back together with pictures if needed. dave
#7 |
Oky, so the name is butterfly, thanks one new word in my database.
Yes, you could do it for me and show how does it works. Thank you! ps.I have relatives in Canada |
#8 |
#9 |
Thank You sreten.
#10 | |
| FS: Japanese Alnico Cone Tweeter / Pair | speaker | Swap Meet | 2 | 28th July 2009 04:13 AM |
| NHT ST-4 how to remove tweeter ? | Chilli6565 | Multi-Way | 0 | 22nd September 2008 05:35 AM |
| Need cone tweeter for Met7 Sequerra | Sylver300B | Vendor's Bazaar | 0 | 24th May 2008 05:53 AM |
| Replacement cone tweeter for Sequerra Met7 | Sylver300B | Vendor's Bazaar | 0 | 24th May 2008 05:53 AM |
| Midange-tweeter dome/cone that can go low | gary f | Multi-Way | 3 | 8th April 2004 08:10 PM |
| Page generated in 0.10626 seconds (79.35% PHP - 20.65% MySQL) with 10 queries |
