Old 13th October 2007, 05:17 PM   #1
Taterworks's Avatar
Default First-Order Lowpass Filter with a Cap
Hi, everyone.
I've seen a couple of examples where in a parallel crossover, a capacitor in parallel with the midbass was used as a lowpass filter. Can this be done without the load ever appearing to the amplifier as a dead short?
If it works, but you don't know why it works, then you haven't done any engineering.
Taterworks Audio (nothing for sale)
Old 13th October 2007, 08:59 PM   #2
Svante is offline Svante  Sweden
Svante's Avatar
No, a first order lowpass typically has a coil in series with the driver. Just a capacitor in parallel with the driver will not be healthy for the amplifier.
It is possible, but hardly clever, to use a parallel capacitor combined with a series resistor. This will attenuate the signal in the passband by 6 dB.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 14th October 2007, 03:49 AM   #3
Taterworks's Avatar
What about the DiAural crossovers? They use a cap in parallel with the woofer, and an air-core inductor in parallel with the tweeter.
Old 14th October 2007, 05:12 AM   #4
owdi is offline owdi  United States
owdi's Avatar
Links? That sounds like a basic series crossover.
Dan
Old 14th October 2007, 09:30 AM   #5
planet10's Avatar
http://www.t-linespeakers.org/tech/filters/diaural.html
The diaural XO differs from a basic series XO in that it adds a power wasting resistor in parallel with the woofer. (it did get them a patent & lots of hype)
To use a cap as a low pass filter you need to have it and the woofer in series with something else that ensures that the amp has something to drive above the XO frequency. (ie a coil & a tweetre in a basic series 2-way)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th October 2007, 02:43 PM   #6
Svante's Avatar
Ah, yes, that's a series crossover. It does not work without the inductor.
...or...
Without the inductor, it can be seen as the RC filter I wrote about. The tweeter will blow pretty soon, though, without the inductor.
Old 14th October 2007, 02:55 PM   #7
audiobomber's Avatar
LOL! Is that what all the hype was about? I remember reading about the amazing circuit that was going to revolutionize the speaker industry, and countless raves over some little demo speaker that outperformed the big boys. Then suddenly..... dead silence, no more talk about DiAural crossovers.
Your post brought up a few questions, so I did a search and found this. http://www.diaural.com/, which pretty much answers all of them.
Dan
4th order lowpass with one transistor AudioAngel Solid State 2 18th April 2007 06:42 PM
Lowpass Filter Layout Wynand Subwoofers 4 1st February 2006 07:06 PM
1st attempt of 2nd order active lowpass filter failed, please advise SimontY Parts 111 15th February 2005 11:32 PM
Coldn't resist: feedback from 4th order lowpass !! phase_accurate Class D 23 13th December 2004 05:01 PM
lowpass filter failure theChris Analogue Source 15 14th April 2003 03:36 PM
Page generated in 0.10042 seconds (85.15% PHP - 14.85% MySQL) with 10 queries
