Here is a project I've been working on for about 3 months. The plan is 2 way with 15 Exodus subs and a Hemp Acoustics 8"DIY fullrange. The system will most likely be an active crossover setup. The 15 Drivers from Exodus will be mounted in 15" PVC pipe 16" long. The pipes will then be bolted to thick MDF pieces that I'm routering with templates.
Ya I know some early pics were posted in the "Subwoofer" forum a month ago, Didn't get to feed back from there. Here is some pics of the build so far. If anybody has any input or sees any potential problems let me know. |
#2 |
Close up of the template
#3 |
Here Is two of the pipes they are about 1/2inch thick with the bendable birch on the outside.
#4 |
More template cut outs
#5 |
Here is the first mock up of most of the pieces stacked up together. The bottom cut out has not been done yet that is a week or two out yet.
The 15's fit flush in the end of the PVC pipe, and the 8" Hemp Acoustics driver will be mounted in the larger top baffle. |
#6 |
Here is a shot from the back. The PVC was originally green so I painted it black on the inside.
#7 |
And one more closeup of the side where the middle baffle meets the 2 pipes. The finish on the pipes will be African Mahogony and the baffle pieces will be done in rotary Birch.
#8 |
I am planning to use your system
#9 |
When you say you are planing on useing my system what do you mean by that? Same drivers? Similar design? Pictures of it? I'm just wondering thats all.
#10 |
My first pass through your posts I thought the tubes were for something like a 7" midwoofer, and the bit sticking out the top was for a tweeter. Then I read the posts closer (instead of just looking at the pretty pictures), then I took a closer look at the picture looking out the garage door. Those things are huge!
I have used Fostex full-range drivers before, but never seen or heard an OB-full-range. Interesting idea, I really like the idea of all that extra surface area for the u-dipole bass. I wonder how high the 8" will operate as a dipole? I am sure the back radiation will be significantly different at very high frequencies from the front, but I wonder where highs will start to drop off. Do you have any testing on the 360 radiation? |
| Dipole Ribbon tweeter isolation from dipole mid-woofer array | Bent | Planars & Exotics | 5 | 21st May 2009 12:10 PM |
| (WW) MMTMM dipole – 4 vs 3 way / dipole benefit frequencies? | charliemouse | Multi-Way | 25 | 7th July 2007 11:19 PM |
| Dipole/Bipole Surrounds (Can anyone build them for me) | NicolasGaal | Swap Meet | 0 | 7th January 2004 04:28 AM |
| Dipole/Bipole Surrounds (Can anyone build them for me) | NicolasGaal | Multi-Way | 1 | 7th January 2004 04:25 AM |
| When is a dipole not a dipole anymore? | Bas Horneman | Multi-Way | 5 | 5th December 2003 03:02 PM |
| Page generated in 0.09226 seconds (81.78% PHP - 18.22% MySQL) with 11 queries |
