Old 9th October 2007, 04:54 PM   #1
tubee is offline tubee  Netherlands
tubee's Avatar
Default gspeakers install
I want to install gspeakers on my pc with linux ubunty 7.04. Tried several times, no result. Can anyone help me guide me through the process?
Thanks!
Daisy Bell
Old 9th October 2007, 11:58 PM   #2
Can you describe what you did and what went wrong (error message) so i can try to help you ?
Old 10th October 2007, 04:26 AM   #3
tubee's Avatar
Thanks for reply Rastafazz
Here is instruction page:http://gspeakers.sourceforge.net/doc...uxinstall.html
First i begin as suggested with spice install. Putted spice3f5sfix.tar.gz (/home/jw/Desktop/spice3f5sfix.tar.gz_FILES ) on desktop
Then in terminal:
jw@Pentium1800:~$ ./util/build linux install
bash: ./util/build: No such file or directory
I have send a mail to the mailadress in Sweden, it came back.
Daisy Bell
Old 10th October 2007, 01:42 PM   #4
I think you have forget to untar the archive or go to spice directory.
Here are all the steps.
go into the directory where you've downloaded spice3f5sfix.tar.gz (cd directory_name)
i will assume it is spice here
and run to following
cd spice
tar xvzf spice3f5sfix.tar.gz
cd spice3f5sfix
./util/build linux
let me know how it goes.
--stephan
ps: if you can't go to the right directory
add this three commands and start again from cd spice
wget http://www.ibiblio.org/pub/Linux/app...3f5sfix.tar.gz
mkdir spice
cp spice3f5sfix.tar.gz spice/
Old 10th October 2007, 05:31 PM   #5
tubee's Avatar
Well, it was some work, also for the machine Never seen in term. something lasting that long. Think i have spice now, saw btw errors coming along. Can i check if i have spice?
These are the few last lines in terminal: (post all will diyaudio's site allmost explode!)I saved the whole in an editer forpossible referral
make[3]: *** [multidec.o] Error 1
make[3]: Target `recursive' not remade because of errors.
make[3]: Leaving directory `/home/jw/Desktop/spice3f5sfix/obj/bin'
Done with spice3f5sfix/src
make[2]: Leaving directory `/home/jw/Desktop/spice3f5sfix/obj'
make[1]: Leaving directory `/home/jw/Desktop/spice3f5sfix'
Done with build at wo okt 10 19:32:02 CEST 2007
jw@Pentium1800:~/Desktop/spice3f5sfix$
The wget didn't work, he could not find package (even after he found site)
Daisy Bell
Old 10th October 2007, 06:10 PM   #6
No, spice won't work.
It seems that libtermcap is missing.
Let me check which package has it.
--stephan
Old 10th October 2007, 07:34 PM   #7
Hi again,
Compiling spice seems to need more than just libtermcap.
There is an easier way. I've tried it on my machine and it seems to be ok: gpeakers launched successfully and it could have a curve.
You need to install these packages if you don't have them already
libxml2-dev
libgtkmm-2.4-dev
automake1.7
gnucap
then download gspeakers
tar xvzf gspeakers-0.11.tar.gz
cd gspeakers-0.11
./configure
make
sudo make install
and then
gspeakers to run it.
Let me know if you have any problem with this.
--stephan
Old 11th October 2007, 05:52 PM   #8
tubee's Avatar
Thank you for helping me on the way Stephan, it's allmost done i guess.
First i checked in synaptic and added libgtkmm-2.4-dev and automake1.7, rest i had allready.
With gspeakers install he missed some other applications:
jw@Pentium1800:~$ cd /home/jw/Desktop/gspeakers-0.11
jw@Pentium1800:~/Desktop/gspeakers-0.11$ ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for g++... no
checking for c++... no
checking for gpp... no
checking for aCC... no
checking for CC... no
checking for cxx... no
checking for cc++... no
checking for cl... no
checking for FCC... no
checking for KCC... no
checking for RCC... no
checking for xlC_r... no
checking for xlC... no
checking for C++ compiler default output... configure: error: C++ compiler cannot create executables
See `config.log' for more details.
Btw i copied-pasted gspeakers-0.11 from desktop, and removed the ¨, and enter. This is the way i learned here: http://monkeyblog.org/ubuntu/installing/
C++ misses, and i think all the 'no' answered items are from spice, but not sure.
Daisy Bell
Old 11th October 2007, 07:34 PM   #9
you need to install g++ packages to be able to compile
or if you want to make thing easier i can send you a precompiled package.
ps: if you install gnucap you don't need to compile the other spice package.
Old 13th October 2007, 05:13 PM   #10
tubee's Avatar
I didn't succeed, i think first to install spice again, gspeakers seeks for crossover items in terminal
I will be away for a week.
Daisy Bell
how do I install an LED jdbrocious Parts 7 1st March 2008 11:18 AM
New Sub And Amp Install Staticjeep Car Audio 0 2nd June 2006 06:21 PM
new install maxiboy Car Audio 6 26th June 2005 10:06 PM
Amp install Help PlEaSe. ebwilliams Car Audio 5 8th September 2004 03:28 AM
How do i install a cap? mcyates Multi-Way 7 21st February 2003 08:20 PM
Page generated in 0.10831 seconds (79.96% PHP - 20.04% MySQL) with 10 queries
