do you think it will work?
Old 8th October 2007, 10:25 PM   #1
drummer6pc is offline drummer6pc  United States
Default do you think it will work?
i have a set of fisher home stereo speakers but one of them has a blown woofer in it so my idea was to change the woofers out with 15" celestion speakers that i have. the celestions originaly came from a marshall bass cabinet. i was wondering if anybody would know if i can actually run this type of speaker with a home stereo amp without hurting the speakers
thanks
Old 8th October 2007, 10:38 PM   #2
3-LockBox is offline 3-LockBox  United States
Depends on the crossover point of those original woofers...well, if they they have crossovers.
Shouldn't be a problem. Anything will be better than the stock Fisher woofers. While you got the woofer out, brace the hell out of those cabinets.
(insert clever anecdote here)
Old 8th October 2007, 10:47 PM   #3
well i just didn't want to hurt the celestions by maybe under powering them but i will try it out and see what happens
thanks
Old 8th October 2007, 11:24 PM   #4
BHTX is offline BHTX  United States
BHTX's Avatar
Not to even mention xover points (if there even are any, as previously mentioned), freq response or anything else, I'm guessing those Celestions might be a bit more sensitive than the fisher woofers, and it's very possible that they could also be very high QTS drivers..which could lead to some very nasty low end, especially if those fisher cabinets are vented. However, I guess it's also needless to say that the original "design" probably wasn't so great either. If they're blown and the Celestions fit, sure why not, see what happens. And unless it somehow actually turns out souding somewhat decent and you get crazy with the volume, don't worry about blowing the Celestions, they should be fine. If you did manage to blow them, I'd say it was probably most likely due to improper tuning of the cabinet, especially if it's a vented enclosure. Have fun..
Old 9th October 2007, 03:27 AM   #5
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
It will work in the sense that you will get sound out of it... The chances of getting any fidelity are very low. Guitar speakers are purposely not flat.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th October 2007, 09:40 PM   #6
well i did it, and it works really well actually however, i did find that they do throw a hell of a lot more bass but it was nothing to eq out. now i think i own the best fisher speakers ever. thanks for the input guys!!
Old 9th October 2007, 09:40 PM   #7
i only did this for my basement stereo so it doesn't have to be that great of sound i just wanted to use the celestions for something other than dust collectors
do you think it will work?Hide this!Advertise here!
Would this work ? LesPaulStandard Instruments and Amps 3 4th May 2006 02:14 AM
Will This Work? sousmielie Class D 6 27th December 2005 05:53 PM
It Should Not Work ! f4bok Solid State 3 6th September 2004 05:33 PM
Would this work? JoeBob Solid State 5 18th July 2003 03:40 PM
Copyright ©1999-2017 diyAudio
