Old 8th October 2007, 05:13 PM   #1
Default Mixed cap & coil values in 12db/octave
For 5.6uF in 6db/octave, high pass would be at 7000Hz
For 0.22mH in 6db/octave, low pass would be at around 2900Hz
Wonder is there a calculation to determine what is the xover value if i put a cap with 5.6uF, and parallel with a coil of 0.22mH, in a 12db/octave butterworth network?
Old 10th October 2007, 01:11 PM   #2
no one can help??
Old 10th October 2007, 01:24 PM   #3
Did it Himself
richie00boy's Avatar
The filter is unlikely to have a Butterworth response but it will be 12dB/octave. Butterworth (or any other alignment) requires a specific ratio between the two parts.
As for the results - easiest and best is just to simulate it.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
L-R 12db/oct tweeters reversed or not? kscharf Multi-Way 8 25th August 2010 04:22 PM
Jamo Concert 8 Xover Coil Values Thomo Multi-Way 6 20th October 2008 07:30 AM
ESP 12db xover help sagarverma Solid State 4 20th October 2005 03:15 AM
Is 12dB/octave sufficient for subwoofer? skyraider Subwoofers 13 27th February 2005 03:21 PM
Crossover Experts! Hole in 12dB/octave, (both sides), response? Help!! kelticwizard Multi-Way 14 17th July 2002 08:45 AM
Page generated in 0.06407 seconds (66.52% PHP - 33.48% MySQL) with 10 queries
