My very old empirical on ear adjusted ML-TQWT need to be replaced.
I want to design a d'Appolito ML-TQWT with two Peerless HDS exclusive mid-woofers and a B&G ribbon tweeter in dipole. How do i handle the TSP with 2 drivers in one enclosure, Vas, Qts, Qm divided by 2? I have a TQWT excel spreadsheet to calculate it. Have been searching for a spreadsheet to design a ML-TQWT, anyone know one? Thanks
Daisy Bell |
#2 |
Using Martin King's MathCad worksheets might be a better start. They do cost $25, but you get the set, and they are accurate, which is more than can be said for the few TQWT sheets for Excel that are lurking around.
Wired in parallel, Vas & Sd double, Re & Le /2. In series, Vas, Sd & & Bl double, everything else remains ~constant. |
#3 |
Thanks for reply scotmoose , good tip. Are the mathcad files also working on linux ubuntu? (i have installed Maxima, for the same purpose as mathcad.)
Daisy Bell |
#4 |
Honest answer, I haven't a clue, knowing nothing at all about Linux. If the software can run MathCad files, then it should be able to run the worksheets. That's all I can tell you I'm afraid.
#5 |
tubee,
I've been looking for that TQWT spreadsheet for quite a while now, if it's not too much to ask, could you please send it to my email? thanks in advance! djquan128 (at) hotmail (dot) com |
#6 |
Word of warning, if it's a Weems based sheet, it won't work very well.
#7 |
djQuan, just google and i found it. Do you want the inch or metric version? Anyway, just sent them.
Daisy Bell |
#8 |
Scottmoose: I can ask somewhere around on the specialists if it will work on Linux. I have on old laptop w2k for kids-games, but i like linux a lot more, also because win cannot find the network card!
Daisy Bell |
#9 |
@ tubee
got them. thanks very much! |
#10 |
Maybe it's better to choose a TL instead of a ML TQWT, less boomy freq response/ flat response with slow roll off to low frequencies
Daisy Bell |
| BDS spreadsheet questions | weinstro | Multi-Way | 2 | 3rd July 2008 11:03 AM |
| Le Cleach spreadsheet | jdruley | Multi-Way | 2 | 24th November 2007 04:55 AM |
| John Rutter TQWT spreadsheet | PTSOUNDLAB | Multi-Way | 2 | 9th June 2006 05:15 AM |
| Resistor spreadsheet? | vinnie | Parts | 3 | 29th January 2006 05:59 AM |
| Best-ever T/S parameter spreadsheet. | Circlotron | Multi-Way | 21 | 20th March 2004 10:25 AM |
| Page generated in 0.10709 seconds (80.35% PHP - 19.65% MySQL) with 11 queries |
