Ok, I had someone build me a pair of cabinets with a bass matrix, ala the edgar beers eveII. Through some miscommunication, the matrix holes are only 1" in diameter. So there are 8 holes total on each panel, 4 on the left 4 on the right. obviously the drawings have the hole diameter much larger. the problem is the cabinets are pretty much finished...so besides volume reduction are there any other negative effects? should i try to dremel out a larger hole...although that might be difficult given i can only work through the woofer cutout.
I guess if volume reduction is the only problem then i can live with it. |
#2 |
Greets!
Sounds like the baffle/brace will act as an internal resistive vent of sorts, so I imagine it will cause a notch somewhere in its BW, though probably high enough up in its BW that it will be attenuated by the XO, ergo not an issue worth dealing with unless you're a perfectionist. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
| Does size really matter - SE Output | wicked1 | Tubes / Valves | 19 | 13th March 2008 05:25 AM |
| PCB Hole Size | ptah | Parts | 10 | 30th November 2006 01:51 AM |
| Does physical size matter | still4given | Power Supplies | 4 | 25th November 2004 08:26 AM |
| Does Size Matter | sirius98 | Multi-Way | 11 | 10th November 2004 03:27 AM |
| Size does matter.. | dutch diy | Multi-Way | 3 | 19th July 2001 09:30 PM |
| Page generated in 0.07869 seconds (67.90% PHP - 32.10% MySQL) with 10 queries |
