Hello,
accidentaly a little bit of sawdust entered into the horn tweeter (fostrex FT17H). ![]() ![]() you see that white piece of wood that stopped right into the fissure? I tried to blow that, but no way. I tried to vacuum clieaning it but it's still there. I was thinking to use the air compressor, but I don't want to damage the tweeter. Do you have any ideas? thank you |
#2 |
You could try a "dust-off" spray. Basically, it's a spray with air under pressure - it could work if the piece of wood cannot go even further into the gap. You should still be careful, as the jet is pretty strong.
#3 |
| Why not a ribbon tweeter instead of a horn tweeter? | Curly Woods | Full Range | 9 | 15th July 2009 04:09 PM |
| Horn tweeter | Keruskerfuerst | Multi-Way | 1 | 14th June 2007 12:01 AM |
| DIY tweeter plus horn. | tade | Multi-Way | 0 | 14th August 2005 06:34 PM |
| Horn-loading Ribbon Tweeter? | mefistofelez | Multi-Way | 17 | 9th November 2004 07:58 PM |
| Beyma CP25 Horn Tweeter | Elso Kwak | Multi-Way | 4 | 1st May 2004 07:21 PM |
| Page generated in 0.39090 seconds (97.30% PHP - 2.70% MySQL) with 10 queries |
