Old 3rd October 2007, 04:52 AM   #1
Send a message via AIM to Spasticteapot
Default Audax HM130C0 information?
Does anyone have any measured specs on the HM130C0s, or any information they could give me? I recently purchased a pair that seem to be new aside from a persistent smell of cigarette smoke, and I have yet to assemble a good measuring jig.
Come to think of it, does anyone know how to get the smell of tobacco out of carbon fiber cones?
Old 3rd October 2007, 07:14 AM   #2
5th element's Avatar
http://www.audax.fr/audaxdoc.htm
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 3rd October 2007, 07:55 AM   #3
AndrewT is online now AndrewT  Scotland
Default Re: Audax HM130C0 information?
I only have Audax published data.
8ohm
Fs=46Hz
50W
90db/W
25mm VCdiam
7ohm min imp
6r2 Re
0.39mH VCinductance
11mmVC length
Kapton former
1layer VC
84diam*15thk magnet
0.34kg magnet
1.1T flux
5.97 BL
5mm gap height
3mm Xmax
1.78*10^-3 Cms
3.6 Qms
0.34 Qes
0.31 Qts
0.55 kg/S Rms
6.9g Mms
0.85dm^2 Sd
18dm^3 (L) Vas @Cas
1.4kg speaker weight
115.5 baffle hole diam. This is tight, and my long port that the rear of the speaker had to fire through seemed restrictive, so I added a taper and generous radius at the back to help the "sound" get out & into the box.
Since this is intended to be a mid range unit, T/S should be of little relevance because you should not be running it that low to produce significant bass output. But with Xmax=3mm it could double up as a low quality Bass/Mid (what a waste). It deserves to have at least a 210co to support it. It also goes fairly high (and still smooth) for a mid to allow integration with the HD-3P which had to cross at 6kHz.
The smell must be volatiles in the deposits.
These evaporate and you "smell" them.
If you warm the speaker gently you can evaporate the volatiles more quickly.
Most of this speaker is water proof. I wonder if you want to risk washing it with "gentle for your hands" washing up liquid and a gentle scrubbing action with a fine bristle brush and a couple of rinse brushes afterwards.
regards Andrew T.
Old 3rd October 2007, 08:03 AM   #4
pinkmouse's Avatar
Default Re: Re: Audax HM130C0 information?
Windowlene or similar is the best stuff for all audio cleaning purposes as it leaves very little residue behind. I use it for just about everything, from cleaning big Midas mixing desks to flushing solidified fizzy drinks out of VC gaps in drivers I'm reconing.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 3rd October 2007, 08:33 AM   #5
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
maybe isopropyl alcahol is worth considering, I know its used in situations where you dont want residue.
Old 3rd October 2007, 08:49 AM   #6
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
I had 4 of them (2 for each speaker, flush mounted) on a DIY monitor pair of mine, along with a planar HF unit on their side. I have a measurement of their FR, but its for 2 HMs and a little off axis. They include the particular box diffraction etc. I am posting it here, maybe it can be indicative to you somehow. Subjectively their signature, is a fast, clean, and a bit dark sound. Keep in mind, A' class quality I am talking. Plot's horizontal gray divisions are indicating 1dB each. One of the very useful, very high value for money, lamented Audax units along some of its HDA brethren.
Old 3rd October 2007, 09:17 PM   #7
I was hoping to use these with a Neo3PDR, so I appreciate the info. What sort of box were you using?
Also, would a 100hz xover point be acceptable?
Old 3rd October 2007, 09:28 PM   #8
Salas's Avatar
Bass reflex, kinda short and deep. 100Hz? Gonna use em in a 3way? Or with a mono sub? Way easy for the HMs, the 100s. I was using em doing the bass too. They were hitting 45Hz -3dB, still clean when loud.
Old 3rd October 2007, 10:49 PM   #9
I figured I'd be using them with a mono sub, to be upgraded to stereo subs when I have the room. I think I'll go with a sealed box, though.
Old 4th October 2007, 06:45 AM   #10
Salas's Avatar
Sealed box = best bass in a box. Stereo subs sound better bcs they drive the room modes better. Good choices.
Some information please ivorthedj Multi-Way 2 18th June 2009 02:00 PM
amp information? tadiam Solid State 0 1st December 2007 09:47 PM
HM130C0 - distortion & off-axis? Spasticteapot Multi-Way 3 22nd November 2007 03:34 AM
Kef 104/2 need information Serratoga Multi-Way 2 11th November 2007 06:06 AM
W-422 Information danloani Full Range 0 28th May 2007 03:14 PM
Page generated in 0.13180 seconds (79.73% PHP - 20.27% MySQL) with 11 queries
