http://profesional.beyma.com/ENGLISH/pdf/descarga.php?pdf=SM-115 N.pdf
Was considering using this driver up to around 900 Hz for a Summa like speaker.
The only thing that bothers me is a problem around 350 Hz. One can see it on FR curve as a dip, on distorsion curve as a rise of H3 (?). It also seems to show on impedance curve as a very small bump (zoom PDF doc at least 300% to see it).
What do you think can be the origin of the problem ? Do you think it's a no go beyond 300 Hz ?
Thanks in advance
Thanks in advance
454Casull said:What's your budget?
250 € / 300 $ max per driver. It's not only a question of price of course.
Beyma's SM-115N has interesting T/S parameters :
low FS (for a pro driver) + not too low QTs + big VAS so I can design a ported box using an alignment lower than 5.7, reasonnably low Le, well behaved in upper frequencies, and high efficiency.
