Old 2nd October 2007, 09:10 AM   #1
Default Removing drivers from cabinets
Has anyone got a neat way of easily removing speaker drivers from cabinets? I've got a pair of Dynaudio Finale speakers, which the foam surrounds have perished and need to be replaced. Trouble is, the "permanently elastic" speaker sealant provided by Dynaudio makes it very hard to budge any of the drivers without damaging the finish on the cabinets. I can't seem to lever them off or even pull them out when I get my fingers through the surrounds
Has anyone got any clever ideas?
Smithy
Old 2nd October 2007, 09:32 AM   #2
pinkmouse's Avatar
Gentle warming with a hair dryer may help.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 2nd October 2007, 09:58 AM   #3
Thanks. I'll give it a try.
Old 2nd October 2007, 03:06 PM   #4
polkymon's Avatar
Get the biggest wood screw that will fit in the driver mounting holes and insert it on an extreme angle so that the threads are in contact with the metal and slowly turn it into the cabinet.
If it starts making its own hole try another angle or hole.
Old 2nd October 2007, 03:18 PM   #5
Speakerholic
Cal Weldon's Avatar
Sounds like that would work well with a coarse thread bolt rather than a screw.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 2nd October 2007, 03:45 PM   #6
polkymon's Avatar
Yes the coarser the better as long as it will fit. I have several wood screws that I made the tips blunt just for this purpose.
Old 2nd October 2007, 09:40 PM   #7
Thanks - the heating didn't work, so I'll give the screw trick a try
Custom made speaker cabinets (no drivers) maurycy Swap Meet 0 23rd May 2006 09:03 PM
Suitable drivers for JBL 4560 cabinets steve hawkins Multi-Way 6 11th September 2005 10:58 AM
UK: 4 x Seas L22 RNX4/P Drivers with Cabinets ShinOBIWAN Swap Meet 19 8th August 2005 10:21 PM
Altec 606 Cabinets w/601 Duplex Drivers Benkev Swap Meet 3 22nd May 2005 06:09 AM
Mounting loudspeaker drivers into cabinets (Decoupling) Puggie Multi-Way 4 27th October 2004 03:04 PM
Page generated in 0.08718 seconds (72.68% PHP - 27.32% MySQL) with 10 queries
