Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 1st October 2007, 02:11 PM   #1
Send a message via Yahoo to Rembulan
Default Loudspeaker polarity checker
Hello everybody,
In multi speaker situation sometimes we can made a mistake to place a loudspeaker wire. I have seen some people use a pulse based polarity checker system but I have search around without a result. any body have idea how to build this checker ?
Old 1st October 2007, 02:45 PM   #2
Nordic is offline Nordic
Nordic's Avatar
How about a low voltage low current source like a watch battery connected between the terminals, then note if the cone moves forward or backwards?
Old 1st October 2007, 02:55 PM   #3
djQUAN is offline djQUAN
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
I use a 1.5V or 9V battery.
Old 1st October 2007, 03:00 PM   #4
Thats not a problem if you can see the driver but if you cant see it like in bandpass or horn. thats procedure will gets dificulties
Old 1st October 2007, 05:53 PM   #5
Svante is offline Svante
Svante's Avatar
Run my tone generator with a sawtooth wave and record the sound with a microphone and look at it with my spectrum analyzer (which also shows the waveform).
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 1st October 2007, 07:56 PM   #6
panomaniac's Avatar
The sawtooth wave is a most excellent method to check polarity. I use it all the time.
The pulse checkers you are talking about are common in pro sound. You should ask at a music or PA store. I've never seen one in kit form, but there might be one.
Bibo, ergo sum.
Old 1st October 2007, 08:13 PM   #7
dangus is offline dangus
Elektor Magazine published plans for such a thing, "Phase Check for Audio System", probably in #11 1990. It's also in the book"Build Your Own High-End Audio Equipment".
There's a transmitter box that generates pulses (line and mic level, and audible (if you add a little speaker), and a detector box that works with a built-in microphone or line inputs. I built a set, and it worked. You could probably generate the pulses using an audio editor and burn a CD, which could save building the transmitter box.
It might be on one of the Elektor audio project CD-ROMs, or if you ask a librarian nicely you might be able to get the book through an inter-library loan, or a copy of the magazine article.
Old 2nd October 2007, 08:27 AM   #8
Default Hi everybody
Thanks for any sugestion I have found The schematic that I looking for from rolls, PT102 thats exactly that I looking for
Thread Tools
tube checker audiofan Tubes / Valves 1 25th February 2008 05:04 PM
Polar ToneOhm 700 PCB checker chipco3434 Swap Meet 0 31st October 2007 01:02 PM
How about adding a spell checker? dhenryp Everything Else 11 18th July 2005 05:22 AM
loudspeaker phase checker bong Everything Else 1 27th November 2002 03:08 AM
loudspeaker phase checker bong Multi-Way 2 25th November 2002 12:19 AM
Page generated in 0.08458304 seconds (77.15% PHP - 22.85% MySQL) with 10 queries
Copyright ©1999-2010 diyAudio
