Old 30th September 2007, 01:31 AM   #1
HTRookie's Avatar
Default Unibox/WinISD Port Size Discrepancies
Hello,
I have 4 Tang Band W4-656SB's that I intend to use for modest surround speakers (1 per enclosure). Modelling in Unibox gives me the following:
Std Design: 3.4 litres with a port of 4.27 cm dia & 94.14 cm length
Design by Vb, Fb & Q: 5.0 litres with a port of 4.04 cm dia & 41.71cm length
Modelling in WinISD gives me 3.0 litres, with a port of 3.81 cm dia & 14.78cm in length...
What box volume/port dimensions should I build to, given these discrepancies??
Thanks for any help.
HTR
Old 30th September 2007, 02:03 PM   #2
Ron E is offline Ron E  United States
Ron E's Avatar
The first two are way off. I have no idea what you are plugging into that program, but I cannot duplicate your results.
The last one will work, but is perhaps too small and tuned too high, IMO. Make the box 4L and the port 1.5" Dia x ~21cm long (or use a PR) and you should be OK.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 30th September 2007, 06:34 PM   #3
Norcad is offline Norcad  Norway
Look at this:
4" full range at Home Theater Shack
Norcad
issue WinISD port length Qes/Pe! Amit_112dB Subwoofers 4 4th August 2007 06:26 AM
Port length in WinISD? Marsh Subwoofers 10 1st July 2007 07:42 PM
WinISD vs. UniBox on port tuning dscline Subwoofers 3 27th September 2006 05:39 PM
Winisd port configuration toenail Subwoofers 3 30th January 2006 01:23 AM
newbie question.WinISD and port tubes PTM Multi-Way 4 31st January 2005 08:55 AM
Page generated in 0.07771 seconds (68.82% PHP - 31.18% MySQL) with 10 queries
