I made a good bargain for a set of Scan-Speak 15w/8530k01.
I want to build small speakers to go as my main speakers and buy tweeters that fits 'em good and parts for crossover and wood. At a later time I will also make a center speaker that sounds similiar. Any recommendation for a DIY project using these Scan-Speak bass/mid units? I want the speaker to be maximum 40 cm high or something. Thanks. |
#2 |
You can calculate your own box, so it gets the size you want
www.q-sound.dk has a program for this on their website |
#3 |
Look at http://www.aos-lautsprecher.de/ and more specifically the Studio 12 type.
Looks and sounds really great. Gert |
#4 | |
#5 |
george a |
#6 |
Thanks for the links.
The crossovers are placed outside the cabinets in both speakers....? |
#7 |
Crossover is, according to the design, internal, but it's up to the builder to make the final choice.
The crossover design has to be bought from AOS, they're making a living out of it. Send the guy a mail for a quote. I built the Studio 24 (4 x 15w/9530, 2x D9800). I bought the drivers there, and got the crossover design thrown in the package. This was a very good deal for me, since the drivers themselves were much more expensive here. Gert |
#8 |
works well in an sealer LS3/5a sized enclosure. Points to watch out for with this driver are:-
1) Sensitivity. At 84.5dB it isn't very sensitive. Best to avoid valve amps unless you like listening really quietly. 2) There is a broad response plateau at 2Khz and above. It is a bit like a baffle step and can be compensated for in the same way... I'd match the with a good soft dome scanspeak tweeter 93000 and above. Since there is a big drop between woofer and tweeter sensitivity, the capacitorless "Acoustic Reality" crossover works well. (Acoustic Reality use the scanspeak drivers themselves) |
#9 |
My 8530's are used in a room of 45m2 with no real problems with sensitivity as long as you don't want JBL syle volume (I've mostly grown out of that)
I use 100w per channel with no probs. + subwoofer for critical listening)
george a |
#10 |
Where have you checked prices in Belgium Timolien?
I just took a look at that site you mentioned, and they are a lot more expensive than DIY paradisio in Antwerpen. Take a look at http://www.diyparadiso.com/price/stock-speakers.htm e.g. the revelator tweeter D2905/99000 costs 169Euro at DIY paradisio, that's 60 Euro cheaper! |
| My Vifa/Scan Speak Project - Solen Premium kit | conscious | Multi-Way | 7 | 3rd December 2007 07:43 PM |
| 3-way Scan-Speak | marvii | Multi-Way | 9 | 15th April 2007 04:14 PM |
| Scan speak floorstander project? | mlankton | Multi-Way | 16 | 2nd September 2006 08:53 AM |
| Scan-Speak project | spedmetal | Multi-Way | 6 | 2nd February 2006 10:17 PM |
| RCF vs Scan-Speak | royalmp2001 | Multi-Way | 0 | 12th June 2002 03:11 PM |
| Page generated in 0.09457 seconds (86.08% PHP - 13.92% MySQL) with 10 queries |
