Old 28th September 2007, 02:36 AM   #1
arc2v is offline arc2v  United States
Default 3 Way OB Center Channel Prototype
Well, several months in the making, but I finally got the prototype done.
It's a 3 way design. Dayton 8" RS for the woofers. HiVi B3N midrange, and Neo3 PDR tweeter.
2nd order LR woof to midrange at 500Hz, 3rd order LR midrange to tweeter at 3kHz. There's a LCR notch filter before the tweeter crossover to tame the rising peak on the Neo3 (mostly above 10kHz)
Baffle right now is 1' x 3' pine, but the final speaker will be bubinga and maple.
Still need to play around with the baffle (adding U wings to extend the bass a bit) and the notch filter and tweeter could use some tweaking, but overall I'm pretty happy with the design.
More info as the design unfolds.
Thanks to everyone who helped me research parts of this over the last few months.
Old 28th September 2007, 02:39 AM   #2
Here's the FR for the prototype.
Mic was 18" away, on axis with the tweeter. ECM8000 mic, Room EQ Wizard software, 20 to 20kHz sweep, non-gated.
Need center channel help Ryan_Mc Multi-Way 0 12th February 2009 03:36 AM
Center channel 66Panel Multi-Way 0 25th August 2008 03:48 AM
Center Channel Prototype done.. kingdaddy Multi-Way 17 24th March 2005 02:00 PM
Center Channel wigginjs Multi-Way 6 26th October 2004 01:48 PM
Center Channel bhg41088 Multi-Way 1 5th September 2004 01:57 AM
Page generated in 0.09072 seconds (71.47% PHP - 28.53% MySQL) with 11 queries
