Hallo
I want to make sure that I understand accurately the port dimensions from schematics (see pic attached). The port is PVC plumbing pipe. What is pipe dimension? 2" (50mm) Inside diameter and 2 3/8 outside diameter? If I understand right, the pipe wall would be very thick, about 3/16" (0.476mm). Right now I have PVC with outside diameter of 2" (50mm) and inside of about 1.81" (46mm) wall thickness is 3/32" (2mm) Can I use it? Thank you. |
#2 |
Minimum Port Diameter
To calculate the minimum diameter of the port required to prevent port noises, you will also need to know the following: Xmax = maximum linear displacement (mm) Dia = Effective diameter of driver (cm) Np = number of ports Calculate the minimum port diameter from the following equations: Sd = pi*(Dia/100)^2/4 Vd = Sd*Xmax/1000 Dmin = 100*(20.3*(Vd^2/Fb)^0.25)/Np^.5 where, Dmin = minimum port diameter (cm) AND The port length required to tune a volume of air to a specific frequency can be calculated by using the following equation: Lv = (23562.5*Dv^2*Np/(Fb^2*Vb))-(k*Dv) where, Dv = port diameter (cm) Fb = tuning frequency (Hz) Vb = net volume (litres) Lv = length of each port (cm) Np = number of ports k = end correction (normally 0.732) (taken from diysubwoofers.org written by Brian Steele) |
#3 |
You could use slightly smaller pipe, but the length will change (shorter). Have fun with math!
#4 |
I don’t know the Xmax or the Effective diameter.
But from the later equation and the original tube size I found that the tuning frequency is about 62Hz. I enter this and the new diameter and found that the length is 11.14cm. I did not calculate the minimum port diameter, let’s hope that 1.81" will be enough Thank you. |
| Slot port vs circular port equivalence | Brisso57 | Multi-Way | 12 | 21st February 2009 02:38 PM |
| Single Port Vent Better than Dual Port? | Daveis | Multi-Way | 18 | 15th July 2007 05:12 AM |
| Help calculating box dimensions & port | jim_vt | Full Range | 6 | 5th April 2005 04:08 AM |
| To port or not to port? Newbie with newly built mains | starquake | Multi-Way | 1 | 18th December 2004 12:51 PM |
| Converting port dimensions. | haffe | Multi-Way | 4 | 21st June 2004 06:52 PM |
| Page generated in 0.07928 seconds (70.69% PHP - 29.31% MySQL) with 11 queries |
