What to choose?!
What to choose?!
Old 29th September 2007, 11:10 AM   #11
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
What to choose?!
http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm
Old 29th September 2007, 01:13 PM   #12
Inductor is offline Inductor  Portugal
Inductor's Avatar
Very good basics Shaun,
To read very attentively.
rinx, Fostex has very nice drivers. That will help with a very good design and xover.
Now, if you are looking for a midbass driver, say for between 200-3K make sure the resonant frequency is about or lower 100Hz (70 and 50 or lower is a good mark) so that it doesn't show through (impedance in the mid-band pass).
The same with the tweeter, if you point at 3k and up make sure Fs is lower than 1K being 800Hz a good mark as in the Fostex tweeter FT28D. There you go.
(As an example) If you choose a higher xover let's say 5k then your mid-high (mid speaker in your case) speaker has to have a good or "flat" output to about that frequency.
Another good thing is, you can always point to the xovers presented with the Fostex tweeters as a first look or design for your xover high pass (if there's no need for attenuation). It's a good start. It can also be different of course, but a 1., 2. or a 3.order xover printed there is always well adapted to the driver.
Old 29th September 2007, 11:23 PM   #13
rinx is offline rinx  Estonia
Thank you guys very much for suggestions. The sytem I am gonna do have to be really natural and sound "big"..lots of air in music and should play loud, if I am listening dancemusic. So I already decided for tweeter-it will be 810921. It seems to be quite new driver, but has nice quality.
NOW, the biggest thing is what to take for a midrange, I thing I am gonna cut midrange from 200 and 2-3.5k. So I have read that the bigger is midrange, the natural sound. Is that true?!
Please help to choose on of these-I hope you undestand that from these project I need really good and natural sound. And there gonna be 2 mids ind one speaker, so the system is then MTMW.
So, I have taken a look :
http://www.madisound.com/catalog/pro...oducts_id=1092
http://members.optusnet.com.au/~grad...blackwood.html
... Andy_G likes it and I found even a project with this one, but I am a littlebit afraid, that it wound sound natural and "big" and even I cant use enough power, if I am listening dancemusic.So, what do you think aboutit.And the price is good right now....
Then here is also on mind.
http://www.madisound.com/catalog/pro...oducts_id=1315
..and the third one what is my mind is here, it has really nice flat freq.curve:
http://www.madisound.com/catalog/PDF...ess/830860.pdf
So, can you help my with your suggestions to pick up one of these, OR if you have something better to recommend (50-60 dollars), just let me know.
What to choose?!Hide this!Advertise here!
[Help] to choose AVR griv_brown Class D 0 7th September 2008 02:02 AM
What amp to choose Arne Chip Amps 9 10th August 2007 10:51 AM
Help me choose please fighi77 Tubes / Valves 12 10th June 2007 02:35 AM
To choose my irf 240 gegene Pass Labs 6 2nd March 2007 12:14 PM
Pls Help Choose a Fan JojoD818 Solid State 13 21st March 2003 04:58 PM
