Old 24th September 2007, 11:13 AM   #1
skogs is offline skogs  Norway
Default poor mans strad as center
Hi, im about to build my own home cinema, and have almost decided on building 5 PMS's. these speakers will be perfect for me considering the low cost, high sensitivity, placement friendly and seems to sound very good. the only problem is how i can fit the center speaker!
http://www.troelsgravesen.dk/PMS.htm
this speaker is fairly large, 100 by 50cm. so it will probably be difficult to place it above the screen (going to use projector and screen, something like 1.8*1.2, maybe smaller) and i can definatly not place it underneath.
do you think i could lie the speaker down horisontally underneath the screen? or will the off axis respons be terrible, since the vertical off axis now is horisontal?
can you think of any other solutions? i rrreally want to use these speakers, as they seems like the only ones for me!
could an alternative be to use this speaker http://www.troelsgravesen.dk/3WClassic.htm as the center, and the other four PMS's? or will they sound too different?
(not easy being an perfectionist, and not having lots and lots of money)
thanks alots for answers! i really need help for this one!!
Øyvind
Old 24th September 2007, 05:26 PM   #2
Make up 5 cardboard cutouts and see if you can really live with them ....
L and R for stereo OK... but the rest ? I'd use the top section in a
large wide flat backed wall mounting configuration for front and rears.
/sreten.
Old 24th September 2007, 06:08 PM   #3
herm is offline herm  United States
Some people get a screen that is fairly transparent (acoustically)
and put the speaker behind it.
Most movie theaters are done this way.
As a matter of fact, a DVD created for home use has been remastered
to tone down the center channel because it is mixed much hotter
(+3db?) for the theater. Some High-end theater processors allow for
a one-touch adjustment in case the DVD was not properly re-mastered.
herm
Old 25th September 2007, 09:32 PM   #4
ScottG is offline ScottG  United States
I also like the PMS.. but this is the project I'd now recommend for listening and HT offering excellent value:
http://www.htguide.com/forum/showthread.php4?t=26939
*If* you use the R44 then you could pair that design with the statements as your frontal L&R loudspeakers (if you desired):
http://www.htguide.com/forum/showthr...2&page=1&pp=35
Those TB titanium *foil* mids are *nice*.
perspective is everything
Old 27th September 2007, 02:42 PM   #5
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
can you think of any other solutions?...
Here is a suggestion: W-(M-T)-W that might work and can include electrical down or up tilt if necessary (odd order M-T filter at 2 kHz).
b
1(2)
Old 27th September 2007, 02:45 PM   #6
2(2)
Old 28th September 2007, 09:16 AM   #7
SamL is offline SamL  New Zealand
Default Re: poor mans strad as center
Øyvind
The 3WClassic will be the closest thing to the PMS. They both uses the same tweeter and woofer and the mid on 3WClasssic is only an inches smaller which also using the same material and made by Seas. Both speaker are cross using 2nd order and design by the same designer so they will sound as close as you can get. If you are keen of heading this direction, you can double check with Troels. As both are design by him, I am sure he will be happy to answer your concern.
my 2c
Sam
Poor Man's Strad peace brainerd Multi-Way 73 26th July 2011 09:56 AM
Poor man's strad zimjj Multi-Way 3 22nd August 2009 01:12 AM
poor mans measuring system... nerd of nerds Multi-Way 18 6th September 2004 02:57 PM
Page generated in 0.08477 seconds (86.45% PHP - 13.55% MySQL) with 11 queries
