Hi All,
I'd like to build a small MTM w/ 5.25" woofers. The intent would be to cross this over at about 100 Hz to a subwoofer. To ease integration issues, I'm contemplating a sealed enclosure. The Peerless 831882 stands out as a nice low distortion, high value driver. However, I haven't found much in terms of success stories for this driver in this application. What should I be expecting? Assuming I'm using the tool correctly, Unibox indicates an F3 of 110 Hz or so with a pair of these drivers in a sealed box. I suppose I could apply a Linkwitz transform to get the desired "Q" and F3 frequency. Is this a bad idea? Unibox also indicates that the SS 15/8530 would work great, but that costs a whole lot more than the Peerless. If the 831882 won't fly, is their a better alternative? |
#2 | |
b 1(1) |
#3 |
Wow, bjorno. Thanks for taking the trouble to run a simulation on my behalf!
Looks like the results are not vastly different than what I had with Unibox, so I appreciate the validation, and also the input that this result is basically usable. |
| FS: 2 Peerless Exclusive 831882 5.75's | kappa546 | Swap Meet | 0 | 10th January 2009 12:25 AM |
| FS: Peerless 831882 Exclusive 5.75" woofers | omarmipi | Swap Meet | 1 | 26th April 2008 07:32 AM |
| Anyone have project plans utilizing the Peerless 831882 (5.25") Exclusive Driver? | omarmipi | Multi-Way | 0 | 12th March 2008 09:51 PM |
| Peerless Exclusive 831882 - 5.5 build | Shim | Multi-Way | 0 | 6th October 2007 02:17 PM |
| need help on my config | hacknet | Solid State | 14 | 2nd December 2002 03:43 PM |
| Page generated in 0.06592 seconds (80.96% PHP - 19.04% MySQL) with 11 queries |
