I have a quick question regarding port placement. I know in general you try and keep your port opening and exit the ports diameter away from any walls or obstructions. But a design I am fiddling with has the 4 inch flared port roughly about 2.5 inches away from the motor and basket of the subwoofer. Will I run into any problems if I go this route or should I just scrap the design?
#2 |
Since it's a subwoofer you shouldn't have any problems as the main problem with a port that is close to the back of the driver is midrange being reflected out of the port which sounds really nasty.
| placement of port | rv1890 | Multi-Way | 1 | 8th February 2006 10:51 PM |
| First attempt question: Cone and port placement | Thalyn | Subwoofers | 2 | 25th July 2005 11:12 AM |
| Quick question about port placement | owdi | Multi-Way | 9 | 1st October 2004 05:38 PM |
| Port placement on MTM | squidbait | Multi-Way | 2 | 25th March 2004 02:26 AM |
| Question on port placement??? | Javaman | Multi-Way | 0 | 16th October 2003 01:34 PM |
| Page generated in 0.07231 seconds (62.82% PHP - 37.18% MySQL) with 10 queries |
