Old 23rd September 2007, 04:19 PM   #1
Send a message via Yahoo to darw82
Default Why speaker become sounding compressed, when played too loud?
Why most of speaker become sound compressed or "break" when played too loud? of course other than clipped source problem.
1. Is it because of the material?
2. Generally, which one of the following material allowing us to
drive the speaker (mid woofer) really hard?
- Paper
- Kevlar
- Rigid carbon
- Polypropylene
Thank you.
Old 23rd September 2007, 04:29 PM   #2
compression occurs as the voice coils heat up.
this reduces the current because of increased resistance
If small gauge wire coils used this could also be happening.
Sheldon D
Old 23rd September 2007, 04:35 PM   #3
AndrewT is online now AndrewT  Scotland
the combination of light weight and fibre construction makes paper very good for high sound pressure levels.
It is used almost exclusively in PA duty.
Small voice coils may be more susceptible to compression than big VCs.
regards Andrew T.
Old 23rd September 2007, 05:29 PM   #4
chops is offline chops  United States
chops's Avatar
One of the joys of using high efficiency PA drivers for the low end and compression drivers/horns for the top end. For home use, I doubt you would ever get compression from these types of drivers. At least I never have.
Charles
Old 23rd September 2007, 08:12 PM   #5
Brett's Avatar
I agree. The OP's issue is likely small, low efficiency 'phile drivers that are being pushed very hard to get any sort of decent SPL.
Old 23rd September 2007, 08:21 PM   #6
Originally posted by Brett
....... low efficiency 'phile drivers........
The low efficiency is a direct trade-off for wide bandwidth. If you want loud, you use lightweight cones and accept the narrow bandwidth.
If you need wide bandwidth you MUST SACRIFICE something and loss of efficiency is much easier to sell than enormous size and multiple drivers.
regards Andrew T.
Old 23rd September 2007, 08:29 PM   #7
Brett's Avatar
I'm well aware of this, but I know where I prefer the compromises. If the wide BW is it so you can have a small, inefficient, dynamically constipated two way, then I'd rather use my STAX 'phones.
Old 23rd September 2007, 10:53 PM   #8
chops's Avatar
Well, we'll see just how "narrow" the bandwidth of high efficiency PA loudspeaker drivers really are once I get my Usher D2 clone project underway. If mine measure anywhere near the D2's, I should be getting down into the low 20's, high teens, and pretty much flat up to the xover point of 600-760Hz.
Granted, I'll have FOUR 15" drivers in FOUR 8.3cf ported enclosures tuned to 26Hz to do it, but I'll also have all the dynamics in the world with 98+dB efficiency per channel.
Charles
Old 23rd September 2007, 11:04 PM   #9
auplater's Avatar
Sounds kinda serious...
Is this for your bedroom system?
John L.
"...His brain is squirming like a toad..." Jim Morrison
Old 23rd September 2007, 11:25 PM   #10
Cloth Ears's Avatar
Like Lowther drivers? DX2 30Hz-20kHz @ 97dB/W/m.
But, you're right about sacrifice, even the cheap ones will set you back $500 each.
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
Is your speaker better sounding them B&W 800 Series? harrisni Multi-Way 27 8th March 2007 04:07 PM
make your own loud speaker. and I mean it metalinspired Multi-Way 12 24th September 2005 01:10 PM
How to make a speaker more forward sounding andy2 Multi-Way 51 3rd September 2005 01:11 PM
Has anybody played with multiple identical speaker placement in HT? leadbelly Multi-Way 9 13th December 2004 01:28 PM
loud speaker 6 ohm resistance petros Multi-Way 1 29th December 2003 05:27 PM
Page generated in 0.13079 seconds (80.52% PHP - 19.48% MySQL) with 10 queries
