I dream to DIY "Wharfedale Airedale Heritage", please help me - Page 2 - diyAudio
Old 23rd September 2007, 12:29 PM   #11
jmateus is offline jmateus  United States
jmateus's Avatar
Hi Langtuhanoi
Have you considered the Ariels?
These are one of the best Diy speakers available for a long time.
I really enjoy mine after all these years. MTM's, two way in a tower
or just simple enclosures much smaller.
It's worth to take a look at them....
JLH 2005, Cyrus and so on...
Old 24th September 2007, 03:53 AM   #12
langtuhanoi's Avatar
Thank
I am sure what I like the speaker design with big cabinet look like Airedale. So, I am searching some best DIY speakers design
Old 24th September 2007, 05:51 AM   #13
el`Ol is offline el`Ol  Germany
Here is a 4-Way speaker with dome midrange:
http://www.visaton.com/en/bauvorschl...848/index.html
Old 24th September 2007, 11:15 AM   #14
Brett,
The challenger series look to be better quality than the HP15w, but I think they don't have low enough Fs, they're all around the low 40s, HP15w is ~35 Hz, probably still not low enough.
The Airdale goes down to 25Hz, so we need a 15" driver that is efficient, has largish Vas, and will go that low.
I once had a similar dream to Langtuhanoi about the old Tannoy York Cab, I ended up choosing the 10" Peerless 850146, which would be perfect for this application, but unfortunately is no longer available....
Langtuhanoi, an alternative to 1x 15" woofer would be to use 2x 10" woofers, for Hi Fi these are probably easier to get, and would give the same surface area as a single 15".
Most 15" speakers available seem to be for PA or Car Subs, not really suitable
(I'm sure someone will prove me wrong)
Pete McK
Old 24th September 2007, 11:19 AM   #15
Hic hic
I see that now the big driver (15") less than others driver. It is the same performance, isn't it? and thay don't want to use the big driver again
I want the depth of sound (bass) is quite clear, so I think the big driver is designed for it
Old 24th September 2007, 12:14 PM   #16
I just modelled a pair of SEAS L26RFX/P 10" woofers in Unibox,
In a 180 Litre cabinet tuned to 24.5 Hz, that looks to be a pretty good way to emulate the Airedale's size, response and tuning at the low end...
Old 24th September 2007, 12:25 PM   #17
langtuhanoi,
The Airedale design is follows the old 1950s/60s way of doing things, that was what they had to do to get deep response in those days.
Many modern drivers are much better, so you can get as good or better response in a smaller driver compared to many of the old drivers (some will disagree of course...).
Most people (or their wives) prefer smaller cabinets nowadays, another reason why 15" isn't common in home audio.
So don't get stuck on a 15" driver...(of course a smaller one won't LOOK as impressive )
Old 24th September 2007, 12:27 PM   #18
Can you share with me diagram design
Thank you
What is about the cabinet?, How it take the sound?
Old 24th September 2007, 01:22 PM   #19
Well, the Tannoy York is similar to the Airedale,
you could scale it to 180 litres and tune the ports according to the drivers you choose:
http://www.44bx.com/tannoy/images/YorkDiag2.gif
Old 24th September 2007, 01:25 PM   #20
more info on original Airedales here:
http://www.audioheritage.org/vbullet...light=airedale
Vintage Wharfedale 12" styrofoam-cone woofer GordonW Swap Meet 2 27th June 2016 04:03 AM
Wharfedale Tweeters - WxxD Series "Amethyst" Diaphragm ARRAY Swap Meet 1 17th July 2010 05:08 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Anybody know "Heritage" loudspeakers chipco3434 Multi-Way 1 13th March 2007 01:43 AM
"....This is not a Dream.... KBK The Lounge 20 27th February 2005 10:19 PM
Copyright 1999-2017 diyAudio
