Hi All,
I've been using ProAc Studio 200 for 12 years, and the tweeter seems to be going bad now. I hear some high-frequency distortion sound occasionally, and it sounds like the tweeter in bad shape. I unscrewed the driver to find out the model number and it is read: 25 TFFC-C H563 - 6ohm I know this driver is a Seas one, but their website or Madisound.com doesn't show this one. I guess I'll have to find the closest one among available Seas tweeters, and I need to find the one that will fit into this driver's place on this speaker. Could somebody help me to find a good substitute? Thank you. |
#2 |
Contact Proac?
#3 |
#4 |
Make sure it isn't a failing capacitor in the cross-over before yee spend thee money..
www.kta-hifi.net |
#5 |
Thank you all for your replies.
I contacted ProAc dealer in the US before, but they didn't provide information, and only tried to sell their overpriced 'custom' replacement drivers. That's why I am looking for 'generic' Seas replacement. To be accurate, I didn't contact ProAc headquarter in England. Thanks for 25TFFC PDF URL. As I don't see the model name on Seas product table or Madisound catalog, I guess I will have to find out the mechanically compatible ones myself using the information. Am I right? Regarding the advice of falling capacitors, both speakers are going bad, so I can't do that test. Is there other way to examine the crossover easily without oscilloscope? |
#6 |
Old post?
#7 |
Greetz,
Thank you for your suggestion. How can I test whether it is due to the post or not? |
#8 |
I thought I've seen this post before, but it was about the ProAc 200 with the scan speak tweeter:
" Several year ago my friend speaker is broken at left tweeter,the standard tweeter use scanspeak 9500,he order from scanspeak and get new one,but after we replace the driver,very different sound with the original pro ac scanspeak driver...than we order from pro ac with give our serial number.pro ac send the scanspeak 9500, same model with standard scanspeak...but the sound is very different,better than standard,sound stage back to focus,high is same in both speaker...that why you must replacement the driver if want 100 % original sound. " But to confirm the tweeter issue; I've got the 25TF and it is looks a lot like the 25T-family, and you could try the seas for the price. The T/S are allmost identical, so no problems expected there... |
#9 |
Thank you for your reply. I misunderstood your 'post' as the 'binding post' and thought you suggested to check the binding post. I will try to find a replacement for 25TFFC which seems discontinued. I found the replacement voice coil for 25TFFC at Madisound. I asked how I can replace only the part of the driver.
#10 |
The US ProAc Rep is at ModAudio@aol.com. His name is Richard. He is VERY helpful and knowledgeable!
Just in case ProAc has them modified for their specs! Repairing with a kit might not sound the same! I found when I needed Mid/woofers for my ProAc Studio I MKIIs they weren't much more that Scan-Speaks from Madisound, like $20 more for both shipped! Good Luck! Regards//Keith
If Wile E. Coyote had enough money to buy all that ACME ****, why didn't he just buy dinner? |
| Tweeter Replacement for Paradigm Studio 60 v3's? | jwglista | Multi-Way | 0 | 2nd April 2009 06:31 PM |
| Event Studio Precision 8 loud static from tweeter | coolsat | Multi-Way | 0 | 28th August 2008 07:41 AM |
| 2 way studio monitors with 10inchwoofer and 1inch ss tweeter design help... | rhythmdiy | Multi-Way | 2 | 10th October 2007 09:43 PM |
| Replacement drivers for ProAc Studio 150 | rafalc | Multi-Way | 3 | 12th July 2005 01:14 PM |
| Woofer replacement for Rogers Studio 1A | Maurice | Multi-Way | 1 | 19th November 2004 06:47 AM |
| Page generated in 0.10657 seconds (77.16% PHP - 22.84% MySQL) with 10 queries |
