Old 15th September 2007, 07:11 PM   #1
shlomid is offline shlomid  Israel
Default Box size for Madisound swifty kit
Hallo
I have read lot of threads in this forum and now building my first speaker.
I want to start with small project so I ordered the swifty kit from Madisound.
I have small room for them so I will position the speaker about 40cm or less, from the rear wall.
The original box is 12" high and has a rear bass reflex port
http://www.madisound.com/catalog/PDF/Swifty.pdf
I wonder if I can make the box higher and move the port to the front without changing the crossover.
Thank you for your help
Shlomi
Old 17th September 2007, 12:22 PM   #2
Yes you can but a rear port will be fine 10cm away from a wall.
/sreten.
Old 17th September 2007, 05:46 PM   #3
Thank you sreten
I will go with the original box then.
Madisound RB in a BIB? mikje Multi-Way 9 9th August 2009 08:07 PM
Replacement woofer for the MAdisound Swifty? JCoffey Multi-Way 0 24th January 2009 04:14 PM
Madisound Swifty Speaker Kit parts cheap!! sbrtoy Swap Meet 3 10th December 2008 05:03 PM
Vifa Swifty kit from MAdisound imperfectcircle Multi-Way 7 12th February 2007 11:20 AM
Help with ar.com kit from madisound Bobhof Multi-Way 15 24th April 2006 10:28 AM
Page generated in 0.07762 seconds (68.46% PHP - 31.54% MySQL) with 10 queries
