Old 15th September 2007, 04:02 PM   #1
speaker is offline speaker  United States
speaker's Avatar
Default Help on driver choice for small sealed speaker
It has been awhile since I've run the catalogues looking for drivers so I am not even sure of the players anymore. I am looking to build a small sealed box 2-way speaker set for my daughter's room that will fit into a wall recess above her desk.
If anyone can point me to some existing small speaker designs that would be great but raw driver suggestions for the woofer are what I am looking for. Something in the 4.5-5.25" range, mid 80's efficiency, & nominal 4-ohms Z is where I would like to start. I estimate the internal volume to be less than/equal to 7L/.25cF.
I am trying to build something that will have decent subjective nearfield bass response when she is close and won't misbehave if turned up if she is across the room. THey will be used alone and without a subwoofer. (An appropriate tweeter match recommendation would be appreciated too.)
Any suggestions or favorites for a woofer like this?
Old 15th September 2007, 04:40 PM   #2
es44 is offline es44  Denmark
es44's Avatar
Not sealed, but i've heard these small boxes, and the first thing i did, was to look for the sub under the table, but there was none
Simply amazing sound, they were driven by a homedone JLH amp, used as a computer sound system.
Max's mini TLS
Sorry, the text is in Danish, but the drawings should speak for them self.
Best regards
Ebbe
Old 15th September 2007, 04:49 PM   #3
sdclc126's Avatar
Best if you could provide a budget, but anyway there are several great compact designs at www.zaphaudio.com
Soft Dome
Old 15th September 2007, 07:57 PM   #4
speaker's Avatar
I appreciate the leads, thank you!
Any others?
Old 15th September 2007, 08:03 PM   #5
sdclc126's Avatar
Look at the projects and kits on Parts Express. Look at Humble Homemade Hi Fi and Troels Gravesen's sites. Look at RJB audio - there's a ton of stuff out there.
Soft Dome
Old 16th September 2007, 12:26 PM   #6
speaker's Avatar
There seems to be more choices for vented rather than sealed. I had really wanted to stay with a sealed design. I am sort of trying to knock off an ADS L200 or L300. I can spend $80-100 on the woofers & tweeters. I'll take any other suggestions.
Old 16th September 2007, 03:12 PM   #7
mace is offline mace  United States
mace's Avatar
Hello Speaker,
Lately i've found myself interested in sealed designs also.
Here is a design that meets your requirements. I don't have any first hand experience with them yet, but should have mine finished here in the next week or so.
Hope this helps
Old 16th September 2007, 04:37 PM   #8
speaker's Avatar
Originally posted by mace
Hello Speaker,
Hope this helps
Although the woofer is bigger than what I was planning to use, my reason for a 4.5-5.25" was that I thought I might have trouble fitting a large woofer in .25cF. I do have the acreage to use a large one however. His design does look like it might indeed work. I also appreciate that he noted how they would be used, on top of a TV. The baffle plane of the TV screen simulates roughly how they would be placed in my own application. Thanks for the link!
Thanks to everyone for all the replies too.
Old 16th September 2007, 04:41 PM   #9
sdclc126's Avatar
This one uses the smaller Dayton woofer - build it sealed and you can use smaller box volume:
http://www.rjbaudio.com/Microbe/microbe.html
Soft Dome
Old 16th September 2007, 06:52 PM   #10
audiobomber's Avatar
Default Re: Help on driver choice for small sealed speaker
Originally posted by speaker
If anyone can point me to some existing small speaker designs that would be great but raw driver suggestions for the woofer are what I am looking for. Something in the 4.5-5.25" range, mid 80's efficiency, & nominal 4-ohms Z is where I would like to start. I estimate the internal volume to be less than/equal to 7L/.25cF.Any suggestions or favorites for a woofer like this?
Creative Sound WR125S, or FR125S work well in a sealed cabinet. Either of these designs could be built sealed:
http://www.vikash.info/audio/FR125S/index.asp
http://www.creativesound.ca/pdf/WR12...25F1Design.pdf
Dan
Which is best choice of driver for Home Theater speaker 5.1 DIY project? langtuhanoi Multi-Way 5 28th September 2008 03:32 PM
Woofer choice in 2-way sealed cabinet tinos5601 Multi-Way 1 13th March 2007 04:55 AM
Which driver for a small sealed box. ShockValue Subwoofers 21 16th June 2005 04:25 PM
Small single driver speaker suggestion (and power rating question) percy Full Range 68 17th March 2005 06:04 AM
Would ported or sealed enclosure be best for this driver in small PA system? The Paulinator Multi-Way 26 25th April 2004 03:38 AM
Page generated in 0.12560 seconds (84.82% PHP - 15.18% MySQL) with 10 queries
