I have been thinking about this for some time and would appreciate your views.
Looking to build an open baffle with 'wings' on the sides - yet to determine the full dimentions but have a couple of 6.5 projects to consider
http://www.troelsgravesen.dk/OBS.htm
http://www.rzaudio.com/rz52/rzss.htm
The driver parameters are as follows:
Dynaudio 17W75xl
Qts 0.46
Qes 0.60
Qms 2.00
VAS 20
fs 40hz
Re 5.1
Le 0.23
Sd 120cm2
Bl 5.7
Sensitivity - about 85 - 87db
It will be mated with a Dynaudio D260, and I already have the Dynaudio recommended crossover built and speakers are housed in teh Dynaudio 25L ported enclosure.
I am looking for more airy mids and highs, and will cross to an active closed box woofer. I will retain the passive crossover for the top.
Do you think this design brief is feasable or ridiculous?
Dynaudio 17W75xl
Qts 0.46
Qes 0.60
Qms 2.00
VAS 20
fs 40hz
Re 5.1
Le 0.23
Sd 120cm2
Bl 5.7
