toning down highrange
Just say i have a speaker that goes from 200hz to 20k (fairly flat) and the bass from 200hz to 80hz is only -4db, can i use some sort of a crossover to "tone down" the 200hz-20k range at a level of -4db.
This would give me a response of 80hz to 20k. I dont care about sensitivity. What about L pads can i get them to cover such a range? thanks |
Seems to me a 10 ohm resistor in series with your crossover for your widerange (you'll need one in their anyway) ought to do about that :) |
sorry i didn't mention it is one full range driver...its a tang band w3-593sf.
im trying to boost its bass by lowering its high range. im still fairly new to this but wouldn't the resistor you just mentioned be for a 2 or 3 way system to lower the db of the mid/highrange drivers |
With a crossover that low you sohould be considering going active.
dave |
Re: toning down highrange
Or am I swinging the wrong end of the cat? You might be able to make do with a R||L||C filter if it's a smooth roll-off from 200Hz down to 80Hz, otherwise I think you might be stuck with only using 200Hz up (or even higher as the big step will affect the crossover anyway). |
the rolloff from 200 to 80hz is quite smooth. Is it worth just sticking to an equalizer to do this job? or is what im saying actually quite possible?
Neither way will be really good unless you get lucky with a great balance of EQ/amp/driver. I'd really start looking for solutions such as having your speaker run full-range , but un-aided - and then look for a set-up (2 bass drivers) to fill in the missing pieces. As you mains already have a 6dB/octave rolloff, you only need to work on a LP filter for your bass at the same slope at about 80-100Hz. So it wouldn't be a subwoofer, just a woofer. |
you are describing a fairly bog standard baffle step compensation circuit, but i find it highly unlikely your speaker is flat 200Hz to 20KHz. Read up on Baffle Step. See the BS circuit here, you probably need something similar : http://www.zaphaudio.com/audio-speaker18.html :)/sreten. |
not exactly fully flat but there in only about 1db difference between 20k-200hz then a smooth rolloff
In principle it works that way:
http://www.visaton.de/de/bauvorschla...anleitung.html But the 200 Hz are too close to the impedance peak of the TB, so you would have to tame the peak with a series notch filter first. |
| All times are GMT. The time now is 07:15 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
