260-140 Dayton XO2W-2K 2-Way Crossover 2,000 Hz
297-406 HiVi RT2C-A Planar Isodynamic Tweeter 295-362 Dayton RS150S-8 6" Reference Shielded Woofer (x2) 260-265 L-Pad 100W Mono 1" Shaft 8 Ohm well the project began as a db616tl and i wanted to put some better drivers in because i got a bigger than expected paycheck from my summer job (W00t). after pricing out a crossover from the db717tl, I decided to get the pre-built one because it was cheaper and easier this being my first project. so all the stuff up there is from parts express and any knowledge you guys can provide is greatly appreciated. (FYI these are being powered by a pioneer 1016tx-v HT amplifier (110Wx7ch., fronts are bi-ampable) and will be the front speakers in a home theater system i am building as i get more money.) |
#2 |
frugal-phile(tm)
The crossover is the most important -- and hardest part to do -- of any multiway speaker. If the XO isn't specifically for the drivers you are using then it is very likely not to turn out well.
A multi-way with a well executed XO will tromp all over a sytem with better drivers but a weak XO. Myself i think XOs are eveil and tend towards 1-way speakers. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
The short answer is it is a disaster waiting to happen. build something like the floor stander of this : http://www.zaphaudio.com/BAMTM.html Or more upmarket a floor stander version of : http://www.zaphaudio.com/audio-speaker16.html or more compact a floorstanding version of : http://www.eldamar.net/audio/RS150MTM/ |
#4 |
A "stock" crossover will not address response break-up peaks inherent with just about any metal woofer, resulting in a harsh, sharp sound that can quickly result in listening fatigue. These peaks are prominent in the Dayton RS line, which are fine woofers for the money by the way. The crossover will need at minimum one notch filter, a steeper slope, and a lower crossover point.
Soft Dome |
#5 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Ok , I looked up the specs on your desired drivers & yes you will need the attentuation for the tweeter as it is rather sensitive & needs the L-pad.
Do we have any response graphs available out there to nail down these anomalies in the woofer? Perhaps you could run the Xover outboard of the enclosure so that we could tweak/modify to make up for the non-linearities. The dirty way to do it of course is to get a twelve band EQ to tweak the response.........Oh yeah..thats' how they do it in the studio!....Plus with said EQ you could dial in the response for room acoustics also. _____________________________________Rick......... |
#6 |
heres the graphs for the woofers
#7 |
and heres the one for the tweeter- but im second guessing the planar isodynamic choice, ive read reviews touting their unmatched clarity but have also hear of poor off-axis response. i think the largest off axis angle in my listening room is 40 degrees, but i really care about the accuracy in the 30 degree range. worst comes to worst, i can always toe the speakers in towards me but then i don't want my friends to think i built poor speakers! Also, i love good soundstaging and detailed sound. Im just wondering if a good dome tweeter would serve me better (around 50-60 dollars)
#8 |
Hmmm.........
what is wrong with the design here that has done all the hard work for you (and not got it wrong in the process) ? http://www.eldamar.net/audio/RS150MTM/ And yes you would be better off with a good dome tweeter. The Seas 27TBFCG is a good choice, the above can use it. |
#9 | |
Soft Dome |
#10 |
I suppose only the best ribbons are worth the effort
| Sanity check - mad about sound lm3886 stereo amp build | KieranC | Chip Amps | 35 | 2nd January 2009 03:30 PM |
| pentode driver sanity check - before i build | zobsky | Tubes / Valves | 5 | 5th July 2006 02:55 PM |
| Sanity check - designing my speaker to be 8ohm amplifier friendly. | owdi | Multi-Way | 4 | 1st November 2005 10:08 PM |
| speaker phase check | sma | Swap Meet | 0 | 12th February 2005 07:45 AM |
| P17WJ speaker box check | Tensop | Multi-Way | 16 | 10th January 2004 12:08 PM |
| Page generated in 0.11924 seconds (78.73% PHP - 21.27% MySQL) with 11 queries |
